AND and AND and adress of
10 posts / 0 new
Ok. So I was going thrue the ansi C specification and somthing struck me about the &var, a&b and && opperators. Acording to the order of priorety the & operators have highter prio then the && operator so
a & b && c is the same as (a & b) && c. But if this is true sholdent
a&&b be interpreted as a&(&b) a bitwizeand address of b as space caracters are optional in the places they may accure in C? AKA a&&b == a & &b :shock:
Or have I just missread and or missunderstood the whole thing? :oops:
A space may not occur in the logical and operator &&. The form a&(&b) results in the error "invalid operands to binary &".
Your message here - reasonable rates.
sholdent
I'm not a compiler guru but I guess that when the compiler sees a & it goes looking for another & before deciding if it is a & or a &&.
Not true, do an experiment, 'if (x & & y){}', gave compiler error 'invalid operands to binary &', so I suppose the compiler, when looking for 'tokens', specifically looks for "&" or "&&". " " is ignored, yes, outside the 'token', but that doesn't mean you can have a space between "&&". If you have a variable called "counter" you can't spell it "cou nter".
PS Use better grammar and you will get more responses.
Give him a break! He's from Sweden. (Although as I might have mentioned elsewhere, Scandinavians tend to be better at English than a lot of natives).
The lexical analyzer (generated by flex in the case of gcc) will try to build the longest valid token it can before giving it to the parser. So, '&&' will be returned as a single token, '&&' will be returned as two '&' tokens. The parser never sees the white space, the lexer strips it all out. The parser (generated by bison in the case of gcc) uses operator precedence to disambiguate between infix '&', as in a&b, and prefix '&', as in taking an address: &thing.
I was surprise the compiler whined about a&(&b). Seems like a reasonable thing to do to me. Maybe you have to cast it to an int to make the compiler happy? a&((int)&b)
-dave
Also, since you seem to be just starting to climb the learning curve on C operators, be aware that & and && are two very different things. '&' does computation. '&&' is short hand notation for an 'if' statement. '&&' and '||' are called "short crcuit" operators.
0 & exp ; // expression is evaluated, bit-wise and'ed with 0, result is zero.
0 && exp ; // 0 is tested, and found 'false', so exp is *guaranteed* *not* to be evaluated. The generated code contains a branch.
pointer!=NULL && pointer->stuff == testvalue; // good
pointer!= NULL & pointer->stuff == testvalue; // very, very bad.
-dave
-dave
Yes, the cast works, but I was surprised to get an error rather than a warning about incompatible types.
:shock:
Jonn! Att furst i gott angri bat wenn i raid jor rityng in thu parent isis i fell more hapi.
Yes, the message doesn't give much of a hint as to what is going on. But I'm not going to throw stones -- getting good error messages for expression evaluation out of a C compiler is a tough job.
:lol:
Juhun! Yuoo hefe-a mestered zee Ingleesh lungooege-a perffectly! I boo doon tu yuoor mestery! Bork, bork, bork!
