'<<' operator
13 posts / 0 new
Hi all,
Could anyone explain the operator '<<' used in these cases:
PORTB |= (1 << PINB.0);
PORTB &= ~(1 << PINB.0);
Is it used to clear/set bit PORTB.0?
<< is logical shift left, >> is logical shift right, bitwise.
1<<PINB.0 shifts "1" times PINB.0, that by 0 or two positions. Result of such operation would be thus 1 if PINB.0 is 0 and 2 if PINB.0 is 1.
The Dark Boxes are coming.
For bit manipulation details:
Smiley
The << shifts a 1, PINB.0 times.
If the individual PINB pins are defined as:
#define PINB.0 0
#define PINB.1 1
#define PINB.2 2
#define PINB.3 3
#define PINB.4 4
#define PINB.5 5
#define PINB.6 6
#define PINB.7 7
so:
PORTB |= (1<< PINB.3);
This is equivelent to:
PORTB |= (PINB & 0b00001000);
and:
PORTB &= ~(1 << PINB.3);
is equivelent to:
PORTB &= (PINB & 0b11110111);
So:
PORTx |= (1 << PINB.x)
and
PORTx &= ~(1 << PINB.x)
are actually used as a mask to isolate and manipulate individual I/O pins within PORTx.
thanks svofski.
I don't understand the purpose of using "1<<" in the commands.
In atmega128 datasdeet, page 22, there is a C code example which is written as
/* Write logical one to EEMWE */
EECR |= (1<<EEMWE);
/* Start eeprom write by setting EEWE */
EECR |= (1<<EEWE);
Suppose EECR=0x00 (EEMWE=0, EEWE=0) , after the two commands are executed, what is the value of EECR?
Can u explain more?
Oh, I see. Thanks all.
microcarl, it is a very good tutorial 8)
Mats
Carl makes a point but you can't really write
#define PINB.0 0
in "normal" C, so I guess this is some particular AVR-specific compiler? Which compiler is that, how PINB.0 is defined?
After your datasheet quotation, EECR will have both EEMWE and EEWE bits set (provided that they are not write-only bits). EEMWE and EEWE in the code example you mention are defined as numbers of bits EEMWE and EEWE respectively. In a 8-bit word, the least significant bit, LSB, is bit 0 and the most significant bit, MSB, is bit 7.
I don't have that datasheet handy but it is not important for understanding of << operation. Suppose EEWE is defined as "3", just for example. Then
EECR |= 1 << EEWE;
translates into less dramatic:
EECR = EECR | (1 << 3);
which would perform a logical OR between current EECR value and another 8-bit word, value of which would be? - your guess please.
Mats Bjorkman wrote:
microcarl your defines has the same PINB.0 all over...
[edit] but it is a very good tutorial 8)
Mats
Thanks! I fixed the .0 error.
Code:
#define PINB.0 0
And neither can I using ImageCraft. I only used
#define PINB.0 0
because that was the format the OP used.
But I can, in fact use:
#define PINB_0 0
#define PINB_1 1
#define PINB_2 2
#define PINB_3 3
#define PINB_4 4
#define PINB_5 5
#define PINB_6 6
#define PINB_7 7
PORTB |= (1 << PINB_3);
and:
PORTB &= ~(1 << PINB_3);
Which is just fine with me.
Is CV the only compiler that provides this extension?
#define PINB.7 7
The CV help file doesn't state clearly, but experiment indicates that this isn't
the way it works -- a reference to PINB.7 gives either 0 or 1 (as svofski suggests),
so an equivalent expression would be:
#define PINB.7 ((PINB & (1 << 7)) >> 7)
First thought is that the OP code isn't what was intended, or is at least
unnecessarily obscure.
Does any of this need to be added as a codicil to Eric's tutorial that I linked to above?
Smiley
That CV's extension is actually pretty nice. Although it is widely believed that for example GCC easily optimizes code like
PORTA |= (1 << 5)
into single SBI instruction, this doesn't always work in more complex expressions. Just yesterday I had to use some inline assembly just to fight off one very stubborn thing, it was a time-sensitive piece. Probably, just probably, it could be unnecessary if GCC had stuff like PINB.7.. But this is only a rant.
