AS7 Production file (elf) not compatible with AS4
5 posts / 0 new
Having been forced to update to AS7, and move to JTAG Ice 3. ( Too much grief with AS4 not finding the old dev tools ). I find myself with the following problem.
My chips are programmed by someone who only has XP and AS4 using AVRISPMk2..
I normally create a complete elf file that programmed to Flash,, eemem and fuses using AS4.. all has run well for ages.
I've just created a production file using AS7 which works fine for me with AS7, but crashes AS4.
Is this a known format incompatibility, if so any workaround?
( Does not want to buy new PC just to load win7 etc )
TIA.
If the .elf is only for production - try building it without any debug info (IIRC the -g option controls that). The newer toolchains produce debug into that is incompatible with AvrStudio4.
-- Nigel
Use avrdude in stead of Studio. Modern versions can read ELF and because it does the ELF reading with libbfd it will work.
OK, Thanks will try these ideas out.
(you can also use tools like avr-objcopy to remove troublesome sections from a .elf file, so that it ends up containing ONLY the sections relevant to programming.)
