simple branch/compare question
4 posts / 0 new
here is a simple predicament that seems to have me temporarily baffled due to a lack of sleep. My program was acting up & I found a simple branch might be the problem.
say temp=r18 contains 33 hex. I want to add 20 hex to this value & and branch whenever volts=r19 is less than this sum:
ldi temp, data ;get the value
subi temp, $E0 ; "ADD" 20
cp volts, temp
brlo do_it ;volts<= temp+20
This seems to work, but if temp is, say $F3, then adding $20 gives $13. Then a value such as $F5 will not be "lower" than the sum as intended. Essentially the rollover will screw everything up. I can program a workaround with a lot of tests & manipulations--but is there a simple wayto avoid these types of rollover problems?
What is the range of "data" and "volts"? Your description above implies that both "data+20" and "volts" can exceed $FF.
In this case, the straightforward method to solve this problem is to use 16bit calculations:
ldi tempL, data        ; get the 8bit data
clr tempH              ; zero-extend data to 16bits
subi tempL, low(-$20)  ; "ADD" $20 to temp
sbci tempH, high(-$20)
cp voltsL, tempL
cpc voltsH, tempH
brlo do_it             ;volts < temp+$20
So, that will work. But it does require a couple of extra registers to store tempH and voltsH.
For your example where "data"=$F3, "temp" will be $0113, and the brlo branch will be taken when "volts" is in the range of $0000..$0112.
If volts is always >= $20, there's another solution you can use. Instead of adding $20 to "data", subtract $20 from "volts":
ldi temp, data         ; get the value
mov temp2, volts
subi temp2, $20        ; subtract $20 from volts
cp temp2, temp
brlo do_it             ; volts < temp+$20
In this case, if "data"=$F3, the branch will be taken when "volts" is between $20..$F2 or $00..$12.
The lower range causes a branch because the code subtracts $20 from "volts". So, when "volts"=$12, "temp2"=($12 - $20)=$F2, which is less-than $F3.
I'd suggest using the 16bit version, unless you absolutely, positively know that the range of "data" and "volts" will allow the 8bit code to work.
--Brian
PS. Rather than directly typing "$E0", I find it more convenient to type what I mean: "-$20", and let the assembler figure out that it equals $E0.
PPS. You original comment for brlo had a "<=" in it, but brlo branches only for "<".
"This thread is like "deja vu all over again" [Yogi Berra]"[theusch]
Heh, I'm reading the other one right now.
I read this one first, and was quite excited to be able to make the first response... But, It turned out that I was really about 10 posts late.
If anyone else reads this thread, go here instead: https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&p=242443#242443
-Brian
