Memory overflow of 2KB on atmega328 16KB | WHAT?
14 posts / 0 new
I'm getting this error:
Severity    Code    Description    Project    File    Line
Error        Program Memory Usage     :    2464 bytes   7.5 % Full
                Data Memory Usage         :    2390 bytes   116.7 % Full    (Memory Overflow)
but the 328 has memory of 16KB?
What am I doing wrong here?
Code is everything, code is life :D
32K Flash - but only 2K RAM: http://www.atmel.com/devices/atm...
M328 only has 2K bytes of SRAM. Data Memory = SRAM! Definitely over-full!  32K bytes of program memory.
Okay, how can I reduce ram than? I have alot of calculations with arrays? Something with malloc? Haven't worked with them before.
Thanks for the info
Malloc uses sram, also. So does stack. If you are using more than 75% to 80% of sram, you also have no room for stack!
Big user can be strings. Use PROGMEM or newer methods to keep constant strings from being copied into sram.
If it is ram-intensive, you may need to migrate to a device with more data memory!
Yes progmem is working nicely, thank you!
Remember, you really need to keep the used data space under 75-80% of the available sram.
I will, thank you.
If you have a bunch of strings and they are not declared as flash, they get copied to ram at poweron and soak up ram.
PROGMEM is the old way to do it. If you are writing new code and using an up to date compiler life gets far simpler if you switch from PROGMEM to __flash.
I was just recently doing some audio work that needed to use program memory and I was trying to remember what the new way of doing it without the PROGMEM and pgm_read_byte. In the end, I didn't bother to search for it because it was a quick throwaway prototype and just wanted to get it done but I will need to remember about __flash for later! Thanks, Cliff!
My digital portfolio: www.jamisonjerving.com
My game company: www.polygonbyte.com
gproduct wrote:
Okay, how can I reduce ram [usage] then?
The first thing to do is to find what's actually using all that RAM.
You do this by looking at the so-called Map File - which, as the name suggests, maps out what is using how much memory, and where ...
Some folks (that includes me!) find the output of nm more palatable than wading through the .map file. Your mileage may vary.
Thanks for the reminder:
https://sourceware.org/binutils/...
