Em interferences - what oscilloscope do I need to see them?
9 posts / 0 new
Hi all, you'll like this. I have build a MCU-driven circuitry for driving those ancient split-flap units from a train station. My problem is that each display unit is driven by set of eight 48V signals that power a built-in relay which switches 110V AC built-in motor (1W-2W-3W, depending on unit size). When the display unit reaches the appropriate position, it turns the relay off, stopping the AC mottor.
When the relay goes off and the motor stops, it must induce all kind of EM noises that apparently propagates to my 5V circuitry (wasn't a problem back in 70's), namely to one 74HC164's clock input. I know of various techniques of supressing these transient effects and have indeed employed some (ferrite cores on both ends of cables, 100n decoupling capacitors for each IC), but still the problems persist, because I don't know what frequencies I'm supressing.
Instead of blindly trying snubbers, various capacitances, inductors everywhere, shielding, multiple PCB layers etc., i would like to SEE the transient effects on an oscilloscope and I want to SEE the corrective effect of any action. I'd like to spend like $500.
The Question: Are oscilloscopes in this price category able to record such transients? I have NO IDEA what frequencies may be involved here. Do I need 1Gsamples/s? Do I need an equipment for $100.000?
I'm already fed up with EMI, it is destroying my second project, but this time I'm not giving up :-) I don't really need to complete it anytime soon, it's 80% learning.
Ferrite beads and decoupling caps are for curing other problems. First up, do you have catch diodes on the relay coils?
Does the problem only occur when you're switching the 110vac to the motors? Ie: is it the relays or the load causing the problem. There's also circuit layout to consider. Where are the currents flowing?
A schematic and a picture of your setup might help.
The scope will show the transients. Your problem is broadband, not with a specific frequency, so don't confuse emissions with susceptance.
The tool usually used to track EMI is a spectrum analyzer. A regular oscilloscope is not usually sensitive enough or is it usually able to trigger on such events. Usually.
Further, it is often difficult to correlate what you see in the time domain (scope) to what you see in frequency domain (analyzer).
Add a tracking generator to it (usually an option) to ease EMC diagnosis.
A Vector Network Analyzer (VNA) is an all-in-one for such.
For this thread's case the edge rates may be low enough such that don't need much bandwidth.
There are some relatively inexpensive spectrum analyzers and VNAs with reduced bandwidth.
Otherwise might only need a week or two to troubleshoot; so, rent the instrument.
High Frequency Measurements Web Page
Douglas C. Smith
Technical Tidbit - March-April 2014
Troubleshooting Radiated and Conducted Immunity Problems in the Development Lab
http://emcesd.com/tt2014/tt040114.htm
matkoliptak wrote:
... namely to one 74HC164's clock input. I know of various techniques of supressing these transient effects and have indeed employed some (ferrite cores on both ends of cables, 100n decoupling capacitors for each IC), but still the problems persist, because I don't know what frequencies I'm supressing.
Do need to be especially careful with clock inputs; not too much dV/dt AND not too little (fixes: low pass filter (LPF), Schmitt trigger).
EFT is akin to ESD and lightning (the rise and fall times are roughly similar).
Try a low pass filter that's a T (R-C-R) (2K-47pF-200).
Repetitive EFT can eventually short the IC's ESD protection; a T LPF is a quick patch in lieu of a rail-tied ESD/lightning TVS.
matkoliptak wrote:
... i would like to SEE the transient effects on an oscilloscope and I want to SEE the corrective effect of any action. I'd like to spend like $500.
There are some low price spectrum analyzers.
The following are from the US; browse down for products from EU and China :
Featured Image
RF Explorer – Low-Cost, Handheld, RF Spectrum Analyzers
http://rfexplorer.com/
Tektronix announces affordable portable spectrum analyzer
by
November 04, 2014
http://www.embedded.com/electronics-products/electronic-product-reviews/debug-and-optimization/4436877/Tektronix-announces-affordable-portable-spectrum-analyzer
The new RSA306 features a broad 9 kHz to 6.2 GHz frequency range, 40 MHz real time bandwidth, and weighs in at just 1.2 pounds.
(3490USD)
http://www.mouser.com/new/tektronix/tektronix-rsa306-spectrum-analyzer/
Spectrum Analyzer,Aaronia, Antennas, Screening, EMC,EMV
Handheld & USB Spectrum Analyzer, RF Analyzers, EMF Testers
http://www.aaronia.com/products/spectrum-analyzers/
SIGLENT Technologies America, Inc
Spectrum Analyzer
http://www.siglentamerica.com/pd.aspx?tid=227&T=1
Embedded
Siglent's SDS 2000X oscilloscopes
by Jack Ganssle
July 25, 2018
http://www.embedded.com/electronics-blogs/break-points/4442429/Siglent-s-SDS-2000X-oscilloscopes
... but the scope and SA (spectrum analyzer) are very different animals, the scope being basically an amplifier and A/D, while the latter is more like a superheterodyne radio, which achieves enormous gain and selectivity.
P.S.
At the moment they’re having a promotion where you get a higher-speed scope for the price of a slower version.
Home
News&Events
Siglent Activity
Get Free Bandwidth Upgrade/Options now!
2016-07-06
http://www.siglentamerica.com/qyxwxx.aspx?id=4767&sid=216
3, This promotion is in effect between between 8 July and 8 October, 2016.
matkoliptak wrote:
... EM noises that apparently propagates to my 5V circuitry (wasn't a problem back in 70's), namely to one 74HC164's ...
Well, back in the '70s, you wouldn't have had 74HC - would you?
It would've been real old TTL - which doesn't have the sensitive, high-impedance inputs of CMOS ...
Cool project. I loved watching those change. The original logic that operated the thing might have been all switches and relays.
Put diodes across your relay coils. Separate your 48 and 5 volt supplies carefully. Use LOTS of bypass caps. Maybe even use opto couplers between the relay drivers and the cmos so they're not actually in the same system.
