There's an intermittent bug, I suspect in the code, but possible a hardware problem. Was hoping fresh eyes might see something I missed.
Target device is an ATtiny85. Using Atmel Studio 7 on a Windows 7-64 platform if that matters. This is all built on a breadboard using a tactile board mounted NO button with a 33k pull-down resistor on the input pin. Perhaps the breadboard's the problem?
The program is pretty simple. There is a single button input which should distinguish between a long and a short press. Three LEDs are attached to PB2:PB0, but one is a power indicator and always on (PB1). The other two are toggle to indicate a long or short press of the button.
I realize my debounce method isn't the most effective, but I don't think that is causing the problem. The problem is that the LEDs only sometimes behave as intended. The error varies, but this one in particular should be easy to trace. Namely, a short press results in the long press LED toggling. Hold the button slightly longer and usually the short press LED lights as intended. Hold much longer and the long LED lights as intended.
Sometimes, I've noticed both LED's toggle together which I don't see how that's possible.
I've tried lots of things. No optimization. Lower "KEY_LOCK_PERIOD" values, changing buttons, removing button from breadboard connecting with alligator clips to the button. There is a cascade portion of code that starts out by assuming the key_status was LONG with subsequent if() to reassign the value dependent upon the key press duration. Nothing has seemed to affect behavior.
I'd appreciate suggestions.
/* * timer.c * * Created: 7/19/2016 10:51:59 AM * Author : Sherri */ #define F_CPU 1000000UL #include <avr/io.h> #include <avr/interrupt.h> #include <avr/sleep.h> #include <util/atomic.h> #define KEY_LOCK_PERIOD 250UL // number of milliseconds key is locked out after keypress #define ISR_TIMER_LEN 976UL // time between interrupts in micro seconds // function declarations void KeyLongPress(); void KeyShortPress(); volatile uint32_t uSec_976_cnt=0UL; // counter of 976uS segments volatile uint32_t keydown_ms, keyup_ms; enum keyStatus { NONE, SHORT, LONG }; int main(void) { // ---------timer setup-------------- // USE Timer 0 // Step #1 set the parameters for the timer TCCR0 registers TCCR0A = (1<<WGM01); //value sets timer to CTC mode TCCR0B = (1<<CS02) | (1<<CS00); // value sets prescaler to clkio/1024 // Step #2 Choose the number of ticks to compare to the timer OCR0A = 0; // with prescaler set at /1024, each tick will be equal to approximately 976us (1Mhz / 1024) // OCR0B is a second value for a second compare if desired. // Step #3 Enable the interrupt for the timer OCR0A. When OCR0A matches the timer, the ISR function will execute TIMSK = (1<<OCIE0A); // Step #4 enable the AVR interrupt bit sei(); // Step #5 Add the ISR routine for OCR0A (See below Main module) // -------------Port setup---------------- //DDRB&=~(1<<PB3); // button input DDRB = (1<<DDB0) | (1<<DDB1) | (1<<DDB2); // LED output PORTB = (1<<PB1); // Power indicator LED // initialize uint8_t current_pin_state = 0; // pin state 0 = open, 1 = closed int prev_pin_state = 0; // previous pin state 0 = open, 1 = closed uint32_t key_press_time = 0; enum keyStatus key_status = NONE; uint32_t key_duration = 0; while (1) { current_pin_state = PINB & (1<<PINB3); // detect a change in pin from low to high or high to low // if pin is low... if(!prev_pin_state){ // test for high pin state if(current_pin_state){ // initial detection of key press has occurred. pin high prev_pin_state = 1; // record that key has been pressed // time key press occurred ATOMIC_BLOCK(ATOMIC_FORCEON) { key_press_time = uSec_976_cnt; } } }else{ // prev_pin_state is high // current pin can be either high or low // if high, do nothing. Waiting for key press to end. Watch for pin to go low. if(!current_pin_state){ //current_pin_state is low/unlike previous/key press has ended // check duration of key press, if longer than valid is it short or long press, record prev_pin_state = 0; // record that key has been released // test time: >= 1000 ms is long press. Less than 1000 but more than Key_lock_period is a short, else cancel ATOMIC_BLOCK(ATOMIC_FORCEON) { key_duration = uSec_976_cnt - key_press_time - KEY_LOCK_PERIOD; } key_press_time = 0; // key_status cascades to determine key_status = LONG; if(key_duration<1000){key_status = SHORT;} if(key_duration<0){key_status = NONE;} key_duration = 0; } } switch (key_status){ case LONG: KeyLongPress(); break; case SHORT: KeyShortPress(); break; } key_status = NONE; } } ISR(TIMER0_COMPA_vect){ uSec_976_cnt++; } void KeyLongPress(){ PORTB ^= (1<<PB2); } void KeyShortPress(){ PORTB ^= (1<<PB0); }
