atmel device description xml, python and clawson
11 posts / 0 new
IIRC, earlier this month, clawson posted a link to good information on handling Amel's device description xml files with python.
The post I am thinking of misspelled python.
So far, I have not been able to find it again.
Perhaps someone, e.g. clawson, would be kind enough to help.
The key-word I know (but there's no reason you should) is "avrrread" which led me to:
https://www.avrfreaks.net/forum/b...
I have a rather worrying habit of mis-spelling Python (happens almost every time I try to google a question about it). I think it's the way I type it and the key-rollover limit of my keyboard.
EDIT: forgot to mention - project sit (and SVN) is here:
https://spaces.atmel.com/gf/proj...
Clawson seems to code in a 120 character wide window.  :-(
Are argparse and print the Python 3-specific things in the code?
How do you know if you're a pirate?
It's probably just print/argparse but to be honest I haven't given it a lot of thought as I only ever write for 3 not 2.
Seems perfectly reasonable to me - even the good ol' VT100 could cope with that way back in the 1980's !!
The funny thing is that usually I do write to just column 80 and Pycharm, the IDE I use for Python has a default rule that nags you if lines go past 80 but for this particular code I'm afraid I moved it to 120 as there were some fairly complex lines and a lot of indentation. It should probably be refactored to reduce the cyclomatic complexity. It's true these rules exist to make code more readable and maintainable but the whole thing was written as a "quick and dirty" :-)
To me, too, until I want to print.
I can, if I work at it, but the result is annoying to read.
You just arrr,
skeeve wrote:
You just arrr,
Very grateful I wasn't drinking anything as a read that.
I wondered why you'd asked in the first place, then saw Cliff's keyword typo in #2 :)
joeymorin wrote:
skeeve wrote:
You just arrr,
'Tain't mine.
Got it from the riddle guy at the Minnesota Renaissance Festival.
Does one need to install avr-studio to get the atdf files?
I'm running linux.
I've downloaded both binaries and sources for the GNU AVR toolchain.
I've unpacked the latter.
If they are there, I am not finding them.
I believe so, and my previous efforts to use Linux tools to decompress and spelunk the Studio installer have failed.  I haven't tried recently, however.
