what happen when a event syeteam channel trigger a pin?
4 posts / 0 new
hello dear friends
i want know what happen when a pin .for example pin 7 port e triggered by enent system.
thank you so much
From Manual:
An event normally lasts for one peripheral clock cycle, but some event sources, such as a low level on an I/O pin, will generate events continuously. Details on this are described in the datasheet for each peripheral, but unless otherwise stated, an event lasts for one peripheral clock cycle.
Ozhan KD
Knowledge is POWER
thank you mr keynegad but i dont know when a timer creat a event in pin on port e what happen for pin ? is pin set .or clear .or toggle .?
thank you so much
what happen for pin
It outputs a pulse that is one peripheral clock cycle wide.  If you want the TC to do something different, why not use the CMP channels on the TC directly and leave the Event System out of the picture.
Greg Muth
Portland, OR, US
Make Xmega Great Again!
