Reading the datasheet I didn't find how to choose the right load capacitance of the crystal.
http://pt.mouser.com/Passive-Com... what load capacitance should I choose?
Thank you
Thank you
Have a look at the Atmel Application Note: AVR042 AVR Hardware Design Considerations.
It discusses the crystal's load capacitors in detail.
Have a look at the Atmel Application Note: AVR042 AVR Hardware Design Considerations.It discusses the crystal's load capacitors in detail.
Thank you :)
So looking at the atmega328p datasheet it says:
From the AVR042 app note we take the formula
C=2xCL-CS
where CS is the stray capacitance usually from 5pF to 10pF.
Lets take 22pF for C and 10pF for CS:
22 = 2xCL - 10 <=> CL = (22+10)/2 = 16pF;
So I need to choose a crystal with a capacitance load of 16pF, right?
Hello everyone,
What would happen if one used a ZTT16.00MX Which has a capacitance of 30pF?
(CERAMIC RESONATOR, ZTT SERIES, THROUGH HOLE MOUNT, 3-PIN, 16 MHz)
http://www.digikey.com/product-d...
J
If you use a HF crystal, you need the 22pF capacitors.
If you use the ceramic resonator, you do not need the 22pF capacitors.
In practice, the standard crystals will work just fine. The capacitors will not be that critical. e.g. 15pF - 30pF will work.
Your frequency will be accurate enough. e.g. +-50 ppm with a crystal or +-500 ppm with ceramic.
If you are aiming for +- 10ppm, you need to worry about the spec.
Thank you David for your reply.
The reason I'm using the Ceramic Resonator with built in caps is it is a tidier circuit, i.e. less components.
From what I understand from your response, if I used the component I asked about, I will probably run the MCU at about 15.something MHz instead of 16Mhz.
If this is correct, then my use-case should work because I'm not aiming for precision timing one would use in a clock.
I was just concerned that I might break the MCU.
Warm regards,
Justin
Since you are not making a RTC, the ceramic resonator will be absolutely fine.
Yes, it might be anywhere from 15.992MHz to 16.008MHz. It might even be exactly 16.000000MHz.
A typical 16MHz crystal might be 15.9992MHz to 16.0008MHz
I cannot remember the last time, in over 30 years of MCU experience, when I used anything other than 22pF. As David said, it just works.
I'm would like to use a resonator with an attiny45, is it the same load capacitance as atmega ?
I'm thinking of using CSTCE8M00G55 resonator. Do you think it is correct or I should use an other ?
Otherwise which good quality 8mhz resonator (I don't need more than 1% accuracy) do you recommend with Attiny mcu ?
You will not get any AVR to run reliably at 8mhz.
The internal RC clock works just fine at 8MHz.
It will have 1% accuracy without any problem.
Yes you could use a crystal if you want 0.003% accuracy.
Or a ceramic resonator with 0.03% accuracy.
You will not get any AVR to run reliably at 8mhz. The internal RC clock works just fine at 8MHz. It will have 1% accuracy without any problem. Yes you could use a crystal if you want 0.003% accuracy. Or a ceramic resonator with 0.03% accuracy.
In attiny85 spec "21.4.1 Calibrated Internal RC Oscillator Accuracy" it is written factory calibration is 10%. That's why I prefer to use an external resonator
Why have you said that any avr can not run reliably at 8mhz. What's the problem with this frequency ?
8 milli-Hz?
Yes, the Factory only guarantees 10% calibration accuracy.
In practice, most chips will be 1%.
If you are selling commercial boards, you would need to check the calibration as part of your test procedures because you could not rely on every chip being 1%.
If you use resonator or crystal, you do not have to worry about calibration. You will still have a board test procedure as part of your production. So you don't save any time by not testing the RC calibration.
8 milli-Hz?
Ok catch it :-)
It was 8Mhz
Yes, the Factory only guarantees 10% calibration accuracy. In practice, most chips will be 1%. If you are selling commercial boards, you would need to check the calibration as part of your test procedures because you could not rely on every chip being 1%. If you use resonator or crystal, you do not have to worry about calibration. You will still have a board test procedure as part of your production. So you don't save any time by not testing the RC calibration. . David.
Accuracy is "at given Voltage & Temperature" so I prefer to guaranty the clock using a resonator
But my question was regarding the Built-in Load Capacitance of the resonator: Should I choose 33pf of CSTCE8M00G55 or 10pf of CSTCE8M00G52 ?
Franck
Ok catch it :-) It was 8Mhz
Sorry to be a complete pedant but that would be 8MHz.
Accuracy is "at given Voltage & Temperature" so I prefer to guaranty the clock using a resonator But my question was regarding the Built-in Load Capacitance of the resonator: Should I choose 33pf of CSTCE8M00G55 or 10pf of CSTCE8M00G52 ?
I don't think it is going to make much difference. Page 30 of the datasheet shows a 10pF load resonator with a ATmega128. I would expect the 33pF version to work exactly the same.
If you have a wide Temperature Range and/or Voltage Range, you would need to compensate the RC.
The Resonator frequency will change too. But within your tolerance so you do not need to worry.
If you are at Room Temperature and mains powered, the RC would be fine.
If you are low current battery app, the RC would be less power, faster wake-up, ... but you would need to check calibration in your QC tests.
Personally, I see little point in ceramic resonators. They are less accurate than crystals.
They probably tolerate mechanical shock and vibration better than crystals.
An RC would be be "better" for mechanical stress. But then your whole pcb requires design for shock.
If your product is going to be in a benign office environment, you really do not need to worry about most of these things.
Ok, thanks for the tip
franck007 wrote:Accuracy is "at given Voltage & Temperature" so I prefer to guaranty the clock using a resonator But my question was regarding the Built-in Load Capacitance of the resonator: Should I choose 33pf of CSTCE8M00G55 or 10pf of CSTCE8M00G52 ?
I checked attiny85, atmega128 and ceralock datasheet and couldn't find the 10pf resonator load exemple
Which datasheet are you referring too ?
Edit: found it
The Murata datasheet that I had to Google for myself. i.e. the one with selection guide for your resonator type. http://www.mouser.com/ds/2/281/p16e-522700.pdf
Quite honestly, AVRs will "drive" a crystal / ceramic oscillator very reliably. (Unless it is the mega1284)
If you choose "lowest power" fuse settings, you may not have enough drive for resonators.
What do you mean by "lowest power" fuse settings ?
Brown-out detection low voltage, slow startup or something else ?
Have you looked for that in the clocking section of the datasheet?
Thanks for your answer. Yes I read the attiny85 datasheet that does not have this low power crystal oscillator mode.
I know, I've asked questions on a atmega thread as I though atmega and attiny85 were similar. It looks that it is not the case
In decades of microcontroller work, I have always used an xtal that is a multiple of 16x115200 so I can hit the std baud rates. So convenient to use the serial for debug, changing params.
If resonator is .03%, I'd get one with a baud multiple frequency just like an xtal.
