Is Atmel support dead?
6 posts / 0 new
For at least a month so far I cannot create any support case from here:
http://www.atmel.com/design-supp...
Every time I click "Open support case" I get: The page you have requested is temporarily not available. Please check back later. We are sorry for any inconvenience.
Anyone knows what is going on and how can I open a new support case?
I opened three cases about a week ago without any problems.  (https://secure.atmel.com/Secure/... and etc.)
They were about Programming ARMs in assembly language, so I'm not really expecting them to result in action...
What happens when you click this link: http://www.atmel.com/forms/Secure/verifylogin.aspx?target_url=salesforce&ssotarget=customers%2F500%2Fe%3FretURL%3D%252Fcustomers%252F500%252Fo
Does it also take you to maintenance notification page?
When I click your link I get:
We can't log you in. Check for an invalid assertion in the SAML Assertion Validator (available in Single Sign-On Settings) or check the login history for failed logins.
Nope.  I get a case edit page.  Or a login page and THEN the case edit page...
have you tried logging in at the top "atmel.com" page and then linking to the support page?   What about in a "private window" (which should be equivalent to flushing your cache/etc.)
Topic was discussed here: https://www.avrfreaks.net/comment...
TLDR: Adblocker, Ghostery, the likes and certain IE settings can lead to this message
Thanks all...works fine in Private mode. Crazy stuff.
