Latest Atmel Studio (7.0.1006) fails to compile cycle_counter.c
10 posts / 0 new
I've upgraded yesterday to the latest Atmel Studio and both existing and new project fail to compile when the Delay routine (service) is added.
The reported error is:
Error        recipe for target 'src/ASF/common/services/delay/sam/cycle_counter.o' failed
Error        's' undeclared here (not in a function)    \src\ASF\sam\utils\compiler.h    242
The definition with an error in compiler.h is
#   define OPTIMIZE_HIGH __attribute__((optimize(s)))
and that is used in cycle_counter.c:
// Delay loop is put to SRAM so that FWS will not affect delay time
OPTIMIZE_HIGH
RAMFUNC
Not sure what is changed so that those files built in earlier version of Studio. Anyway, can anybody confirm this error?
I can confirm this happens to me as well after the recent Atmel Studio 7 update.
Anyone found a fix yet?
I've just commented out OPTIMIZE_HIGH for now, I couldn't notice any difference for this fairly inoffensive code (in fact, it's just a dummy while loop AFAIK).
But I'd be more interested in understanding what changes have broken the build.
This is because the gcc version was upgraded to 5.3.1. The erroneous definition of OPTIMIZE_HIGH was present earlier, but gcc didn't warn about it. Atmel will probably push an updated header file soon. In the mean-time, you can change the definition of portable_delay_cycles in cycle_counter.c to:
__attribute__((optimize("Os")))
RAMFUNC
void portable_delay_cycles(unsigned long n)
Can confirm, this only happens with GCC 5.3.1.
Just a quick add: It can be reproduced if you simply add the Delay routines service to a default, empty board project and try to compile it.
This has been fixed already and will be available in the next release of ASF. (See http://asf.atmel.com/bugzilla/sh...)
Thanks everyone for the comments and fix, will use Bugzilla in the future
Thanks all for this post.  I have been killing my self for over 3 weeks trying to figure this one out.
Atmel Support was no help at all and I wasted weeks trying things and waiting on them.
Don't know if that is typical or part of the down sizing MicroChip has done to them.
John Z
JTZ Engineering, Inc
Upgrade your old project to ASF 3.34 and update all the project's ASF source and header files.
I can't remember how I have done it, but I remember some manual editing involved, at least for the migration of the project itself to ASF 3.34.
As for the source and header files, simply create a new ASF 3.34 project with the modules you're using in the old project, and copy the created ASF source folder over the ASF folder of the old project.
Specifically, the 's' needs double-quotes around it... quick fix:
#   define OPTIMIZE_HIGH __attribute__((optimize("s")))
