SAM7 vs SAM4 debugging
3 posts / 0 new
We are in the process of selecting a micro for a new project and are looking at SAM4 and SAM7 series parts.  I have read some info that makes me think that the M7 has a newer and maybe better debug infrastructure.  Has anyone here used both and is there a significant difference that we should take into consideration in our selection process?
Dave M
Dave M
hello
SAM7 (ARM/) parts are a good choice but already up to 10 years old.
So if there is no absolute reason for using SAM7 it would be the better choice in any point of view to use a SAM with Cortex M.
regards
gerhard
"SAM7" are ARM7 parts:
http://www.atmel.com/products/mi...
as gerhardf says, this is a "legacy" architecture.
az10sbum wrote:
 I have read some info that makes me think that the M7 (sic?) has a newer and maybe better debug infrastructure.
Are you thinking of Cortex-M7 ?
http://www.atmel.com/technologie...
That is an entirely newer and "better" architecture all around (or so they'd have us believe)
