changing fount in graphical LCD
12 posts / 0 new
I am working 128X64 Graphical lcd and using lib given on  http://en.radzio.dxp.pl/ks0108/ and successfully interface it with ATMEGA32. I want to change the font of characters form 5X8 to 12X16 . So I make change in function given below in KS108.c
void GLCD_WriteChar1(char charToWrite)
    int i;
    charToWrite -= 32;
    for(i = 0; i < 5; i++)
    GLCD_WriteData(GLCD_ReadByteFromROMMemory((char *)((int)font12x16 + (5 * charToWrite) + i)));
    GLCD_WriteData(0x00);
but this not work. So please help to solve what is wrong.
The magic number 5 appears twice in your code - is it still correct for your new font size ... ?
What is correct no. and what is relation ??? Please tell.
Maybe 5 is "FontWidth"?
You need to take a little more effort to figure out what is happening! What is the purpose of the for() loop?
Does it not step through the symbol that is organized as bytes, each byte for a column of the symbol? So, it steps 5 times to read 5 columns and each column is made up of one byte containing 8 bits. So, to do a 12 by 16 symbol, there will be, at the very least 12 "columns" and each column will contain 2 bytes. Depending on how the font is organized and how the LCD wants its data, you will want to step through one sequence of 8 bytes representing the top half of the symbol, then another 8 bytes representing the bottom half. OR, again depending on how the font is organized and the LCD, you will, for each column, read the upper byte, then the lower byte, then go to the next column.
Then you need to edit up a c file with 128 chars of 12 columns and 16 rows. Here's one that might help a little
This is table I using and as you suggest i use 24 in place of 5. There is change in font but it is not readable.
    int i;
    charToWrite -= 32;
    for(i = 0; i < 24; i++)
    GLCD_WriteData(GLCD_ReadByteFromROMMemory((char *)((int)Font12x16 + (24 * charToWrite) + i)));
static const uint8_t Font12x16[]PROGMEM = {
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "(space)"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0xFF, 0x33, 0xFF, 0x33, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "!"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // """
    0x00, 0x00, 0x00, 0x02, 0x10, 0x1E, 0x90, 0x1F, 0xF0, 0x03, 0x7E, 0x02, 0x1E, 0x1E, 0x90, 0x1F, 0xF0, 0x03, 0x7E, 0x02, 0x1E, 0x00, 0x10, 0x00, // "#"
    0x00, 0x00, 0x00, 0x00, 0x78, 0x04, 0xFC, 0x0C, 0xCC, 0x0C, 0xFF, 0x3F, 0xFF, 0x3F, 0xCC, 0x0C, 0xCC, 0x0F, 0x88, 0x07, 0x00, 0x00, 0x00, 0x00, // "$"
    0x00, 0x00, 0x00, 0x30, 0x38, 0x38, 0x38, 0x1C, 0x38, 0x0E, 0x00, 0x07, 0x80, 0x03, 0xC0, 0x01, 0xE0, 0x38, 0x70, 0x38, 0x38, 0x38, 0x1C, 0x00, // "%"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xB8, 0x3F, 0xFC, 0x31, 0xC6, 0x21, 0xE2, 0x37, 0x3E, 0x1E, 0x1C, 0x1C, 0x00, 0x36, 0x00, 0x22, 0x00, 0x00, // "&"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x27, 0x00, 0x3F, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "'"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x03, 0xFC, 0x0F, 0xFE, 0x1F, 0x07, 0x38, 0x01, 0x20, 0x01, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "("
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x20, 0x01, 0x20, 0x07, 0x38, 0xFE, 0x1F, 0xFC, 0x0F, 0xF0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // ")"
    0x00, 0x00, 0x00, 0x00, 0x98, 0x0C, 0xB8, 0x0E, 0xE0, 0x03, 0xF8, 0x0F, 0xF8, 0x0F, 0xE0, 0x03, 0xB8, 0x0E, 0x98, 0x0C, 0x00, 0x00, 0x00, 0x00, // "*"
    0x00, 0x00, 0x00, 0x00, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0xF0, 0x0F, 0xF0, 0x0F, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00, // "+"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB8, 0x00, 0xF8, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // ","
    0x00, 0x00, 0x00, 0x00, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00, // "-"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "."
    0x00, 0x00, 0x00, 0x18, 0x00, 0x1C, 0x00, 0x0E, 0x00, 0x07, 0x80, 0x03, 0xC0, 0x01, 0xE0, 0x00, 0x70, 0x00, 0x38, 0x00, 0x1C, 0x00, 0x0E, 0x00, // "/"
    0x00, 0x00, 0xF8, 0x07, 0xFE, 0x1F, 0x06, 0x1E, 0x03, 0x33, 0x83, 0x31, 0xC3, 0x30, 0x63, 0x30, 0x33, 0x30, 0x1E, 0x18, 0xFE, 0x1F, 0xF8, 0x07, // "0"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x30, 0x0C, 0x30, 0x0E, 0x30, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x00, // "1"
    0x00, 0x00, 0x1C, 0x30, 0x1E, 0x38, 0x07, 0x3C, 0x03, 0x3E, 0x03, 0x37, 0x83, 0x33, 0xC3, 0x31, 0xE3, 0x30, 0x77, 0x30, 0x3E, 0x30, 0x1C, 0x30, // "2"
    0x00, 0x00, 0x0C, 0x0C, 0x0E, 0x1C, 0x07, 0x38, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xE7, 0x39, 0x7E, 0x1F, 0x3C, 0x0E, // "3"
    0x00, 0x00, 0xC0, 0x03, 0xE0, 0x03, 0x70, 0x03, 0x38, 0x03, 0x1C, 0x03, 0x0E, 0x03, 0x07, 0x03, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x03, 0x00, 0x03, // "4"
    0x00, 0x00, 0x3F, 0x0C, 0x7F, 0x1C, 0x63, 0x38, 0x63, 0x30, 0x63, 0x30, 0x63, 0x30, 0x63, 0x30, 0x63, 0x30, 0xE3, 0x38, 0xC3, 0x1F, 0x83, 0x0F, // "5"
    0x00, 0x00, 0xC0, 0x0F, 0xF0, 0x1F, 0xF8, 0x39, 0xDC, 0x30, 0xCE, 0x30, 0xC7, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x39, 0x80, 0x1F, 0x00, 0x0F, // "6"
    0x00, 0x00, 0x03, 0x00, 0x03, 0x00, 0x03, 0x00, 0x03, 0x30, 0x03, 0x3C, 0x03, 0x0F, 0xC3, 0x03, 0xF3, 0x00, 0x3F, 0x00, 0x0F, 0x00, 0x03, 0x00, // "7"
    0x00, 0x00, 0x00, 0x0F, 0xBC, 0x1F, 0xFE, 0x39, 0xE7, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xE7, 0x30, 0xFE, 0x39, 0xBC, 0x1F, 0x00, 0x0F, // "8"
    0x00, 0x00, 0x3C, 0x00, 0x7E, 0x00, 0xE7, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x38, 0xC3, 0x1C, 0xC3, 0x0E, 0xE7, 0x07, 0xFE, 0x03, 0xFC, 0x00, // "9"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x1C, 0x70, 0x1C, 0x70, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // ":"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x9C, 0x70, 0xFC, 0x70, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // ";"
    0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0xE0, 0x01, 0xF0, 0x03, 0x38, 0x07, 0x1C, 0x0E, 0x0E, 0x1C, 0x07, 0x38, 0x03, 0x30, 0x00, 0x00, 0x00, 0x00, // "<"
    0x00, 0x00, 0x00, 0x00, 0x60, 0x06, 0x60, 0x06, 0x60, 0x06, 0x60, 0x06, 0x60, 0x06, 0x60, 0x06, 0x60, 0x06, 0x60, 0x06, 0x60, 0x06, 0x00, 0x00, // "="
    0x00, 0x00, 0x00, 0x00, 0x03, 0x30, 0x07, 0x38, 0x0E, 0x1C, 0x1C, 0x0E, 0x38, 0x07, 0xF0, 0x03, 0xE0, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, // ">"
    0x00, 0x00, 0x1C, 0x00, 0x1E, 0x00, 0x07, 0x00, 0x03, 0x00, 0x83, 0x37, 0xC3, 0x37, 0xE3, 0x00, 0x77, 0x00, 0x3E, 0x00, 0x1C, 0x00, 0x00, 0x00, // "?"
    0x00, 0x00, 0xF8, 0x07, 0xFE, 0x1F, 0x07, 0x18, 0xF3, 0x33, 0xFB, 0x37, 0x1B, 0x36, 0xFB, 0x37, 0xFB, 0x37, 0x07, 0x36, 0xFE, 0x03, 0xF8, 0x01, // "@"
    0x00, 0x00, 0x00, 0x38, 0x00, 0x3F, 0xE0, 0x07, 0xFC, 0x06, 0x1F, 0x06, 0x1F, 0x06, 0xFC, 0x06, 0xE0, 0x07, 0x00, 0x3F, 0x00, 0x38, 0x00, 0x00, // "A"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xE7, 0x30, 0xFE, 0x39, 0xBC, 0x1F, 0x00, 0x0F, 0x00, 0x00, // "B"
    0x00, 0x00, 0xF0, 0x03, 0xFC, 0x0F, 0x0E, 0x1C, 0x07, 0x38, 0x03, 0x30, 0x03, 0x30, 0x03, 0x30, 0x07, 0x38, 0x0E, 0x1C, 0x0C, 0x0C, 0x00, 0x00, // "C"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x03, 0x30, 0x03, 0x30, 0x03, 0x30, 0x03, 0x30, 0x07, 0x38, 0x0E, 0x1C, 0xFC, 0x0F, 0xF0, 0x03, 0x00, 0x00, // "D"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0x03, 0x30, 0x03, 0x30, 0x00, 0x00, // "E"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0xC3, 0x00, 0xC3, 0x00, 0xC3, 0x00, 0xC3, 0x00, 0xC3, 0x00, 0xC3, 0x00, 0x03, 0x00, 0x03, 0x00, 0x00, 0x00, // "F"
    0x00, 0x00, 0xF0, 0x03, 0xFC, 0x0F, 0x0E, 0x1C, 0x07, 0x38, 0x03, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC7, 0x3F, 0xC6, 0x3F, 0x00, 0x00, // "G"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x00, // "H"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x30, 0x03, 0x30, 0xFF, 0x3F, 0xFF, 0x3F, 0x03, 0x30, 0x03, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "I"
    0x00, 0x00, 0x00, 0x0E, 0x00, 0x1E, 0x00, 0x38, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x38, 0xFF, 0x1F, 0xFF, 0x07, 0x00, 0x00, // "J"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0xC0, 0x00, 0xE0, 0x01, 0xF0, 0x03, 0x38, 0x07, 0x1C, 0x0E, 0x0E, 0x1C, 0x07, 0x38, 0x03, 0x30, 0x00, 0x00, // "K"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x00, // "L"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x1E, 0x00, 0x78, 0x00, 0xE0, 0x01, 0xE0, 0x01, 0x78, 0x00, 0x1E, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x00, // "M"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x0E, 0x00, 0x38, 0x00, 0xF0, 0x00, 0xC0, 0x03, 0x00, 0x07, 0x00, 0x1C, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x00, // "N"
    0x00, 0x00, 0xF0, 0x03, 0xFC, 0x0F, 0x0E, 0x1C, 0x07, 0x38, 0x03, 0x30, 0x03, 0x30, 0x07, 0x38, 0x0E, 0x1C, 0xFC, 0x0F, 0xF0, 0x03, 0x00, 0x00, // "O"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x83, 0x01, 0x83, 0x01, 0x83, 0x01, 0x83, 0x01, 0x83, 0x01, 0xC7, 0x01, 0xFE, 0x00, 0x7C, 0x00, 0x00, 0x00, // "P"
    0x00, 0x00, 0xF0, 0x03, 0xFC, 0x0F, 0x0E, 0x1C, 0x07, 0x38, 0x03, 0x30, 0x03, 0x36, 0x07, 0x3E, 0x0E, 0x1C, 0xFC, 0x3F, 0xF0, 0x33, 0x00, 0x00, // "Q"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x83, 0x01, 0x83, 0x01, 0x83, 0x03, 0x83, 0x07, 0x83, 0x0F, 0xC7, 0x1D, 0xFE, 0x38, 0x7C, 0x30, 0x00, 0x00, // "R"
    0x00, 0x00, 0x3C, 0x0C, 0x7E, 0x1C, 0xE7, 0x38, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC3, 0x30, 0xC7, 0x39, 0x8E, 0x1F, 0x0C, 0x0F, 0x00, 0x00, // "S"
    0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x03, 0x00, 0x03, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x03, 0x00, 0x03, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, // "T"
    0x00, 0x00, 0xFF, 0x07, 0xFF, 0x1F, 0x00, 0x38, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x38, 0xFF, 0x1F, 0xFF, 0x07, 0x00, 0x00, // "U"
    0x00, 0x00, 0x07, 0x00, 0x3F, 0x00, 0xF8, 0x01, 0xC0, 0x0F, 0x00, 0x3E, 0x00, 0x3E, 0xC0, 0x0F, 0xF8, 0x01, 0x3F, 0x00, 0x07, 0x00, 0x00, 0x00, // "V"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x1C, 0x00, 0x06, 0x80, 0x03, 0x80, 0x03, 0x00, 0x06, 0x00, 0x1C, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x00, // "W"
    0x00, 0x00, 0x03, 0x30, 0x0F, 0x3C, 0x1C, 0x0E, 0x30, 0x03, 0xE0, 0x01, 0xE0, 0x01, 0x30, 0x03, 0x1C, 0x0E, 0x0F, 0x3C, 0x03, 0x30, 0x00, 0x00, // "X"
    0x00, 0x00, 0x03, 0x00, 0x0F, 0x00, 0x3C, 0x00, 0xF0, 0x00, 0xC0, 0x3F, 0xC0, 0x3F, 0xF0, 0x00, 0x3C, 0x00, 0x0F, 0x00, 0x03, 0x00, 0x00, 0x00, // "Y"
    0x00, 0x00, 0x03, 0x30, 0x03, 0x3C, 0x03, 0x3E, 0x03, 0x33, 0xC3, 0x31, 0xE3, 0x30, 0x33, 0x30, 0x1F, 0x30, 0x0F, 0x30, 0x03, 0x30, 0x00, 0x00, // "Z"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x03, 0x30, 0x03, 0x30, 0x03, 0x30, 0x03, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "["
    0x00, 0x00, 0x0E, 0x00, 0x1C, 0x00, 0x38, 0x00, 0x70, 0x00, 0xE0, 0x00, 0xC0, 0x01, 0x80, 0x03, 0x00, 0x07, 0x00, 0x0E, 0x00, 0x1C, 0x00, 0x18, // "\"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x30, 0x03, 0x30, 0x03, 0x30, 0x03, 0x30, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "]"
    0x00, 0x00, 0x60, 0x00, 0x70, 0x00, 0x38, 0x00, 0x1C, 0x00, 0x0E, 0x00, 0x07, 0x00, 0x0E, 0x00, 0x1C, 0x00, 0x38, 0x00, 0x70, 0x00, 0x60, 0x00, // "^"
    0x00, 0x00, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, // "_"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x7E, 0x00, 0x4E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "`"
    0x00, 0x00, 0x00, 0x1C, 0x40, 0x3E, 0x60, 0x33, 0x60, 0x33, 0x60, 0x33, 0x60, 0x33, 0x60, 0x33, 0x60, 0x33, 0xE0, 0x3F, 0xC0, 0x3F, 0x00, 0x00, // "a"
    0x00, 0x00, 0xFF, 0x7F, 0xFF, 0x7F, 0x80, 0x61, 0xC0, 0x60, 0xC0, 0x60, 0xC0, 0x60, 0xC0, 0x60, 0xC0, 0x71, 0x80, 0x3F, 0x00, 0x1F, 0x00, 0x00, // "b"
    0x00, 0x00, 0x80, 0x0F, 0xC0, 0x1F, 0xE0, 0x38, 0x60, 0x30, 0x60, 0x30, 0x60, 0x30, 0x60, 0x30, 0x60, 0x30, 0xC0, 0x18, 0x80, 0x08, 0x00, 0x00, // "c"
    0x00, 0x00, 0x80, 0x0F, 0xC0, 0x1F, 0xE0, 0x38, 0x60, 0x30, 0x60, 0x30, 0x60, 0x30, 0xE0, 0x30, 0xC0, 0x30, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x00, // "d"
    0x00, 0x00, 0x80, 0x0F, 0xC0, 0x1F, 0xE0, 0x3B, 0x60, 0x33, 0x60, 0x33, 0x60, 0x33, 0x60, 0x33, 0x60, 0x33, 0xC0, 0x13, 0x80, 0x01, 0x00, 0x00, // "e"
    0x00, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xFC, 0x3F, 0xFE, 0x3F, 0xC7, 0x00, 0xC3, 0x00, 0xC3, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "f"
    0x00, 0x00, 0x80, 0x03, 0xC0, 0xC7, 0xE0, 0xCE, 0x60, 0xCC, 0x60, 0xCC, 0x60, 0xCC, 0x60, 0xCC, 0x60, 0xE6, 0xE0, 0x7F, 0xE0, 0x3F, 0x00, 0x00, // "g"
    0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x80, 0x01, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x00, 0xC0, 0x01, 0x80, 0x3F, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x00, // "h"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x60, 0x30, 0xEC, 0x3F, 0xEC, 0x3F, 0x00, 0x30, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "i"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0xE0, 0x00, 0xC0, 0x60, 0xC0, 0xEC, 0xFF, 0xEC, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "j"
    0x00, 0x00, 0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x03, 0x80, 0x07, 0xC0, 0x0F, 0xE0, 0x1C, 0x70, 0x38, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, // "k"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x03, 0x30, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x30, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "l"
    0x00, 0x00, 0xE0, 0x3F, 0xC0, 0x3F, 0xE0, 0x00, 0xE0, 0x00, 0xC0, 0x3F, 0xC0, 0x3F, 0xE0, 0x00, 0xE0, 0x00, 0xC0, 0x3F, 0x80, 0x3F, 0x00, 0x00, // "m"
    0x00, 0x00, 0x00, 0x00, 0xE0, 0x3F, 0xE0, 0x3F, 0x60, 0x00, 0x60, 0x00, 0x60, 0x00, 0x60, 0x00, 0xE0, 0x00, 0xC0, 0x3F, 0x80, 0x3F, 0x00, 0x00, // "n"
    0x00, 0x00, 0x80, 0x0F, 0xC0, 0x1F, 0xE0, 0x38, 0x60, 0x30, 0x60, 0x30, 0x60, 0x30, 0x60, 0x30, 0xE0, 0x38, 0xC0, 0x1F, 0x80, 0x0F, 0x00, 0x00, // "o"
    0x00, 0x00, 0xE0, 0xFF, 0xE0, 0xFF, 0x60, 0x0C, 0x60, 0x18, 0x60, 0x18, 0x60, 0x18, 0x60, 0x18, 0xE0, 0x1C, 0xC0, 0x0F, 0x80, 0x07, 0x00, 0x00, // "p"
    0x00, 0x00, 0x80, 0x07, 0xC0, 0x0F, 0xE0, 0x1C, 0x60, 0x18, 0x60, 0x18, 0x60, 0x18, 0x60, 0x18, 0x60, 0x0C, 0xE0, 0xFF, 0xE0, 0xFF, 0x00, 0x00, // "q"
    0x00, 0x00, 0x00, 0x00, 0xE0, 0x3F, 0xE0, 0x3F, 0xC0, 0x00, 0x60, 0x00, 0x60, 0x00, 0x60, 0x00, 0x60, 0x00, 0xE0, 0x00, 0xC0, 0x00, 0x00, 0x00, // "r"
    0x00, 0x00, 0xC0, 0x11, 0xE0, 0x33, 0x60, 0x33, 0x60, 0x33, 0x60, 0x33, 0x60, 0x33, 0x60, 0x3F, 0x40, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "s"
    0x00, 0x00, 0x60, 0x00, 0x60, 0x00, 0xFE, 0x1F, 0xFE, 0x3F, 0x60, 0x30, 0x60, 0x30, 0x60, 0x30, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "t"
    0x00, 0x00, 0xE0, 0x0F, 0xE0, 0x1F, 0x00, 0x38, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x30, 0x00, 0x18, 0xE0, 0x3F, 0xE0, 0x3F, 0x00, 0x00, // "u"
    0x00, 0x00, 0x60, 0x00, 0xE0, 0x01, 0x80, 0x07, 0x00, 0x1E, 0x00, 0x38, 0x00, 0x38, 0x00, 0x1E, 0x80, 0x07, 0xE0, 0x01, 0x60, 0x00, 0x00, 0x00, // "v"
    0x00, 0x00, 0xE0, 0x07, 0xE0, 0x1F, 0x00, 0x38, 0x00, 0x1C, 0xE0, 0x0F, 0xE0, 0x0F, 0x00, 0x1C, 0x00, 0x38, 0xE0, 0x1F, 0xE0, 0x07, 0x00, 0x00, // "w"
    0x00, 0x00, 0x60, 0x30, 0xE0, 0x38, 0xC0, 0x1D, 0x80, 0x0F, 0x00, 0x07, 0x80, 0x0F, 0xC0, 0x1D, 0xE0, 0x38, 0x60, 0x30, 0x00, 0x00, 0x00, 0x00, // "x"
    0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0xE0, 0x81, 0x80, 0xE7, 0x00, 0x7E, 0x00, 0x1E, 0x80, 0x07, 0xE0, 0x01, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, // "y"
    0x00, 0x00, 0x60, 0x30, 0x60, 0x38, 0x60, 0x3C, 0x60, 0x36, 0x60, 0x33, 0xE0, 0x31, 0xE0, 0x30, 0x60, 0x30, 0x20, 0x30, 0x00, 0x00, 0x00, 0x00, // "z"
    0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0xC0, 0x01, 0xFC, 0x1F, 0x7E, 0x3F, 0x07, 0x70, 0x03, 0x60, 0x03, 0x60, 0x03, 0x60, 0x00, 0x00, 0x00, 0x00, // "{"
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x3F, 0xFF, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // "|"
    0x00, 0x00, 0x00, 0x00, 0x03, 0x60, 0x03, 0x60, 0x03, 0x60, 0x07, 0x70, 0x7E, 0x3F, 0xFC, 0x1F, 0xC0, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, // "}"
    0x00, 0x00, 0x10, 0x00, 0x18, 0x00, 0x0C, 0x00, 0x04, 0x00, 0x0C, 0x00, 0x18, 0x00, 0x10, 0x00, 0x18, 0x00, 0x0C, 0x00, 0x04, 0x00, 0x00, 0x00, // "~"
    0x00, 0x00, 0x00, 0x0F, 0x80, 0x0F, 0xC0, 0x0C, 0x60, 0x0C, 0x30, 0x0C, 0x30, 0x0C, 0x60, 0x0C, 0xC0, 0x0C, 0x80, 0x0F, 0x00, 0x0F, 0x00, 0x00  // "ein Haus :)"
+1
Actually, the suggestion is that you take time to understand what your code is actually doing!
  • Why was there a 5 in the original code? What was its purpose? How did it relate to the original font size?
  • How does the change in font size affect that?
  • Are there any other changes that also need to made to accommodate the new font size? After all, you have changed it in two dimensions - haven't you ... ?
I think 5 is width of character (in pixel). But it should be 12 for 12X16. So what is wrong. I try 12 and 24 both but result are negative.
You think ?
So what have you done to verify that hypothesis ?
You really need to understand your code before you start hacking with it!
So what is wrong
You have the code there in front of you - nobody else does.
All you provided is a tiny snippet with no comments or description - impossible to tell from that!
You need to understand how the 5x8 font gets drawn pixel by pixel or byte by byte. Maybe its drawn by picking up a column of 8 pix from the table, (after calculating the index of the start of the char in the table) and putting that in display ram in a for loop for 5 columns. So to extend this to 12x16, you need to pick up the top 8 bits and store them, then the bottom 8 bits in the column, repeat this for 12 columns?
+1
Those trusty old tools known as pencil and paper may help here ...
I find graph paper is very helpful in figuring out wayward graphic code.
