MCP4251 with Atmega without SPI mode
27 posts / 0 new
Dear All ,
Any one is having any idea of how to control MCP4251 digital POT using Atmega with normal port pin, I am doing as per Microchip manual but fails repeatedly.
i am using SDI, SCL, CS/ signals.
My code is similar like this : ( Not exactly)
// Start write
        PORTB |= SCK; // clock goes high
        _delay_us(20);
        PORTB &= ~CS; // cs goes low to start write
        _delay_us(20);
        unsigned short mask = 0b1000000000000000; // MSB
        for (int n=0; n<16; n++) // 16 bits, 2 bytes: command byte plus data byte
            PORTB &= ~SCK; // clock goes low
            _delay_us(20);
            // Prepare pin
            if ((output & mask) > 0) // Bit is on
                PORTB |= SI // SI on
                PORTB &= ~SI;
            _delay_us(20);
            _delay_us(20); // stays high for a bit while bit is read by DPOT
            mask = mask>>1; // next bit down
        PORTB |= CS; // CS high again to end write
        _delay_ms(1); //
Pkdas
Not sure why you have those huge delays, the SCLK low and high times of the MCP4251 worst case is 500nS (at lower voltages).
What are the definitions for CS, SDI and SCK?
David
Since you have decided not to show us the real code, I can only guess!
Every where you have a statement like this:  PORTB |= CS;   change it to be PORTB |= (1<<CS), or change PORTB &= ~SI to PORTB &= ~(1<<SI).
This may or may not work depending on how you have CS, SI and SCK defined ( you decided not to show us these defines)
Do the same for SI and SCK  changing them to (1<<SI) and (1<<SCK)
This way your are only changing the single bit of the port and not setting/clearing the other bits.
A logic analyzer would be a very useful piece of gear to use in a case like this.
I use macros for my setting and clearing of bits, so I can use same code in different implementations without have to look for all places port/pin changes are needed.
I am using a AD5293 pot at 5V (so no delays are needed):
#define CLR_SCLK (PORTB &= ~(1 << PB1))
#define SET_SCLK (PORTB |= (1<< PB1))
#define CLR_SYNC (PORTB &= ~(1 << PB0))
#define SET_SYNC (PORTB |= (1<< PB0))
#define CLR_DOUT (PORTB &= ~(1 << PB5))
#define SET_DOUT (PORTB |= (1<< PB5))
void wr_pot(uint16_t data){
    CLR_SYNC;
	for (uint8_t i = 16; i>0; i--){
		SET_SCLK;
		if ((data & (1<<(i-1))) != 0) {
			SET_DOUT;
		} else {
			CLR_DOUT;
		CLR_SCLK;
	CLR_DOUT;
	SET_SYNC;
David
Frogy,  Nice, I've captured that for my library of code snippets!
Just a hint:  With the quoted expression, you are forcing the compiler (in all probability--perhaps your compiler's optimizer is smart enough...) to do a variadic shift each time through the loop.  Consider changing to OP's "test the same bit each time and shift the operand one place each loop to place the next bit in the target location".  The shift direction and bit tested will depend on data order.
	CLR_SYNC;
		SET_SCLK;
			SET_DOUT;
			} else {
			CLR_DOUT;
		CLR_SCLK;
	CLR_DOUT;
	SET_SYNC;
void wr_potx(uint16_t data){
	CLR_SYNC;
	// LSB first
		SET_SCLK;
		if (data & 1) {
			SET_DOUT;
			} else {
			CLR_DOUT;
		data >>= 1;
		CLR_SCLK;
	CLR_DOUT;
	SET_SYNC;
	wr_pot(123);
	wr_potx (123);
Instructions are a bit hard to follow below, but you'll see the embedded shift loop...
00000030 <wr_pot>:
	CLR_SYNC;
  30:	c0 98       	cbi	0x18, 0	; 24
  32:	2f e0       	ldi	r18, 0x0F	; 15
  34:	30 e0       	ldi	r19, 0x00	; 0
		SET_SCLK;
  36:	61 e0       	ldi	r22, 0x01	; 1
  38:	70 e0       	ldi	r23, 0x00	; 0
  3a:	05 c0       	rjmp	.+10     	; 0x46 <__SREG__+0x7>
			SET_DOUT;
  3c:	c5 9a       	sbi	0x18, 5	; 24
			} else {
			CLR_DOUT;
		CLR_SCLK;
  3e:	c1 98       	cbi	0x18, 1	; 24
  40:	21 50       	subi	r18, 0x01	; 1
  42:	31 09       	sbc	r19, r1
  44:	88 f0       	brcs	.+34     	; 0x68 <__SREG__+0x29>
	CLR_SYNC;
		SET_SCLK;
  46:	c1 9a       	sbi	0x18, 1	; 24
  48:	ab 01       	movw	r20, r22
  4a:	02 2e       	mov	r0, r18
  4c:	02 c0       	rjmp	.+4      	; 0x52 <__SREG__+0x13>
  4e:	44 0f       	add	r20, r20
  50:	55 1f       	adc	r21, r21
  52:	0a 94       	dec	r0
  54:	e2 f7       	brpl	.-8      	; 0x4e <__SREG__+0xf>
  56:	48 23       	and	r20, r24
  58:	59 23       	and	r21, r25
  5a:	45 2b       	or	r20, r21
  5c:	79 f7       	brne	.-34     	; 0x3c <wr_pot+0xc>
			SET_DOUT;
			} else {
			CLR_DOUT;
  5e:	c5 98       	cbi	0x18, 5	; 24
		CLR_SCLK;
  60:	c1 98       	cbi	0x18, 1	; 24
  62:	21 50       	subi	r18, 0x01	; 1
  64:	31 09       	sbc	r19, r1
  66:	78 f7       	brcc	.-34     	; 0x46 <__SREG__+0x7>
	CLR_DOUT;
  68:	c5 98       	cbi	0x18, 5	; 24
	SET_SYNC;
  6a:	c0 9a       	sbi	0x18, 0	; 24
  6c:	08 95       	ret
0000006e <wr_potx>:
	CLR_SYNC;
  6e:	c0 98       	cbi	0x18, 0	; 24
  70:	20 e1       	ldi	r18, 0x10	; 16
  72:	06 c0       	rjmp	.+12     	; 0x80 <wr_potx+0x12>
	// LSB first
		SET_SCLK;
		if (data & 1) {
			SET_DOUT;
  74:	c5 9a       	sbi	0x18, 5	; 24
			} else {
			CLR_DOUT;
		data >>= 1;
  76:	96 95       	lsr	r25
  78:	87 95       	ror	r24
		CLR_SCLK;
  7a:	c1 98       	cbi	0x18, 1	; 24
  7c:	21 50       	subi	r18, 0x01	; 1
	SET_SYNC;
	CLR_SYNC;
	// LSB first
  7e:	49 f0       	breq	.+18     	; 0x92 <wr_potx+0x24>
		SET_SCLK;
  80:	c1 9a       	sbi	0x18, 1	; 24
		if (data & 1) {
  82:	80 fd       	sbrc	r24, 0
  84:	f7 cf       	rjmp	.-18     	; 0x74 <wr_potx+0x6>
			SET_DOUT;
			} else {
			CLR_DOUT;
  86:	c5 98       	cbi	0x18, 5	; 24
		data >>= 1;
  88:	96 95       	lsr	r25
  8a:	87 95       	ror	r24
		CLR_SCLK;
  8c:	c1 98       	cbi	0x18, 1	; 24
  8e:	21 50       	subi	r18, 0x01	; 1
	SET_SYNC;
	CLR_SYNC;
	// LSB first
  90:	b9 f7       	brne	.-18     	; 0x80 <wr_potx+0x12>
			CLR_DOUT;
		data >>= 1;
		CLR_SCLK;
	CLR_DOUT;
  92:	c5 98       	cbi	0x18, 5	; 24
	SET_SYNC;
  94:	c0 9a       	sbi	0x18, 0	; 24
  96:	08 95       	ret
Especially with 8-bit data, a walking mask (similar to OP's approach) could well be best.  Certainly makes for simpler code, eliminating the loop counter.
// MSB first
for (mask = 0x8000; mask; mask>>=1) { ... }
ki0bk wrote:
... how you have CS, SI and SCK defined ( you decided not to show us these defines)
+1
Now, as I'd usually ask, tell AVR model and why real SPI can't be used.
@thusch
  You are absolutely correct, I had not previously checked my .lss file with that code.
After some initial testing, I had changed the routine to use the hardware SPI and had left this in an abandoned #ifndef block.
Edit:
Although the POT needs MSB first rather than LSB so a slight modification is required to operate correctly.
David
Previously i had given you the example code that i followed to write down my code & here is my actual code:
//volume step is 0 to 8
//PORTD.4 = CS
//PORTD.5 = SDI
//PORTD.6 = SCL
///// INCREMENT VOL FROM BUTTON
void Vol_Ctrl_Inc()
                if (Vol_stp < 8)
                    Vol_stp++;
                Vol = (Vol_stp * 64)-1;
                Vol = Vol & 0x03FF;
                send_vol_data(Vol);//wiper-1
                Vol |= (1<<12);
                send_vol_data(Vol);//wiper-2
/////DECREMENT VOL FROM BUTTON
void Vol_Ctrl_Dec()
                if (Vol_stp > 0)
                    Vol_stp--;
                Vol = Vol & 0x03FF;
                Vol |= (1<<12);
void send_vol_data(unsigned int SL_Data)
                // Start write
                PORTD &= ~(1<<6);//clk low
                _delay_us(200);
                PORTD &= ~(1<<4);//cs low
                _delay_us(200);
                unsigned short mask = 0b1000000000000000; // MSB for Volume
                for(int Dta_Ct=0;Dta_Ct<16;Dta_Ct++)
                //send data
                    if ((SL_Data & mask) > 0)
                    PORTD |=(1<<5); //data high
                    PORTD &= ~(1<<5); //data low
                    _delay_us(200);
                    PORTD |=(1<<6);//clk high
                    _delay_us(200);
                    //Shift right
                    PORTD |=(1<<4);//cs high
                    _delay_ms(10);
Pkdas
Still, why the large delays?
David
Tell more about that.  Intermittent operation?
The device appears to be "smart" w.r.t. SPI mode 0 or mode 3.  For consistent operation, won't you need to set your MOSI-equivalent signal to an appropriate value for your data transfer sequence?
1. well now i am trying to reduce the delay.
2. I am using Atmega162 for my project and i have already used SPI port for my design aspect, otherwise i had a better choice to use SPI port for my controller & i hope there are lots of example with SPI mode.
3. My request to all of you not to suggest me repeatedly using SPI mode.
Pkdas
Hello, Pkdas -
SPI is constantly being suggested because you CAN have several peripherals on a single SPI bus. It just takes a select line for each peripheral. And you need to manage the select lines, appropriately (activate the one associated with the device you are talking to). Its very common and not a big deal. It is also significantly  easier to use the built-in hardware. I recently had a project with an accelerometer running at 100Hz (new reading every 10ms) AND a micro-SD memory chip on the same SPI bus with no apparent issues.
You realize that you can have multiple SPI slaves on a bus, with separate chip selects.
I don't quite know what you are asking here.  About using the AVR's SPI peripheral?  (Wasn't I the only one mentioning that?)
Or really about SPI >>mode<<?  You still haven't shown your connections, nor your definitions asked for.  Nor what the testing results are.
About the delays:  Nothing wrong with slowing things down when developing.  Especially if you have a lash-up such as a breadboard.
well my controller is atmega 162 & Port B already i am using for DAC 8 bit data , as well as ISP port  for future use.
& so that i cannot use SPI.
i have just now tested the code with way Theusch suggested but not working.
Pkdas
I was only suggesting an alternate method of selecting the needed bit value each pass.
Your responses seem more like objections to us readers, rather than considering what is being asked for and providing it.
If you do not have an ISP port, then how are you programming your microcontroller?
(Just because you use those pins for ISP does not mean that they cannot be used for connection to an SPI peripheral.)
How have you made your connections?  When you look at the pins at the target device with a 'scope, do the signals look clean and change state as expected?
Here is the circuit i am using
Pkdas
read MCP4251 instead of 4241 as 4252 was not available in lib of drawing s/w
Pkdas
Please show a complete test program as requested.  Or, at least, the defines asked for.  Show us the code you are now using.  Tell what you expect to happen, and what >>is<< happening.
(the schematic doesn't really help without those #defines..)
post no #09 in this article already given the actual code & i do not think u really need a #define anything  where direct set/reset bit command (e.g. PORTD &= ~(1<<4);//cs low) already provided!
define ing is really needed every time for testing code every time?
Pkdas
Except PD4 goes to J8
PD5 goes to SCL
PD6 goes to SDI
CS is GNDed
Edit: changed SDA to SDI above.
David
PD5 goes to SCL
PD6 goes to SDI
CS is GNDed
Frog_jr.
I have corrected that one , Now i am using as per code
PD4 for /CS
PD5 for SDI
PD6 for SCL
Drawing is little bit older
Pkdas
Perhaps WP (pin 11) needs to be pulled high?
Edit:
and SHDN (pin12)
David
shdn i made pull high
what is WP i have seen it in pin conf but not details
i will pull it high
Pkdas
WP is (typically) Write Protect.
David
/Shdn  & /WP pin pulled high & Code tested ----- no result
Pkdas
Dear All
Finally i used SPI for this project & dropped the idea of not using SPI.
I have done a lot of work & failure i changed the controller to 2560.
Pkdas
