1 ms CTC delay? Is this correct?
10 posts / 0 new
Is this OK, with 1MHZ internal osc for atmega8?
#include
#include
#include
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
 static double glb_ms_counter;
 static double glb_max_ms;
 static int error_corrector;
ISR (TIMER1_COMPA_vect) //(SIG_OVERFLOW1)
	glb_ms_counter ++;
	error_corrector++;
	if(error_corrector==50)
		error_corrector=0;
		glb_ms_counter--;
	if(glb_ms_counter==glb_max_ms)
		sbi(DDRC,5);
		cbi(PORTC,5);
		while(1){}
	sbi(DDRC,5);
	sbi(PORTC,5);
	sbi(DDRC,4);
	sbi(PORTC,4);
	glb_ms_counter=0;
	glb_max_ms=1000;
	error_corrector=0;
	sbi(DDRC,4);
	cbi(PORTC,4);
	TCNT1H=0x00;
	TCNT1L=0x00;
	OCR1AH=0x00;
	OCR1AL=0x01; 	//for 1ms CTC
	TCCR1A=0x00;
	TCCR1B=0x0D; // CTC + 1024 presclar
	TIMSK|=0x10; // CTC interrupt
	SREG |= 0x80; //global interrupt
	while(1){
	_delay_us(200);
	return 0;
The problem i am facing is, for 1000 counts (1000ms), code is creating delay of 2.12Sec???
There is no code for calibration of the internal oscillator.
Do you use it in the real code?
Artur Lipowski
Yes. Using in real code.
Can you help me to write this calibration code....
Just read calibration values using your programmer. Write it into EEPROM or FLASH (e.g. as a simple const). Then at the begining of your program use it by writing appopriate (for 1, 2, 4 or 8 MHz) value into OSCCAL.
That's all.
Artur Lipowski
1) When using CTC mode to count up to N, you need to set OCR1A=N-1
(refer to Figure 42 in the data sheet), so in this case you need OCR1A=0.
2) It looks (?) as though you're using error_corrector to correct for the fact that
you're actually counting 1.024ms/OC event, rather than 1.000ms. If so, I
think you're correcting glb_ms_counter backwards -- you should be adding
this leap-ms instead. A simpler approach might be to just use prescale /1
and set OCR1A=(1000-1).
3) The internal oscillator can drift by +/- 5% due to temperature/voltage (refer
Figure 179-180); the big discrepancy you're seeing is due to (1)-(2) above.
If you need even higher accuracy than this, you need an external 32kHz
crystal or some other external reference.
Implemented nopresclar option.
Still I get 6.17 sec when i count for 6000 ms.
It could be error of the thirdparty timer and some in mega8's internal oscilator.
YB
I ran into the same problem using a 12Mhz crystal. I haven't figured out the problem yet - it hasn't become that important yet - but I thought mysery may love company. I figured that it was an error in the freq of the crystal. I plan to build a calibration board that has a cheap stopwatch built into it. The Uc would time an event and also start and stop the stopwatch. I would use the difference between the two to correct for the error.
This was using an external crystal? These are normally specified on the
order of 50ppm (0.005%), so a 3% error is huge. Did you set the clock
fuses appropriately?
The drift of the internal oscillator is not theoretical -- I've seen it in action
by carrying my device outdoors on a brisk November evening. It took about
90 seconds before my (moderately finicky) ultrasonics drifted completely
out of spec.
How is a cheap stop watch going to be more accurate than the crystal? How much error are you getting? If it is more than 4 or 5 seconds per day, I would say that there is something wrong with the code, not the crystal.
Steve A.
