Re:Light Dimmer circuit ..Lamp flickers at higher firing angles(for period 4ms to 10ms)
29 posts / 0 new
Dear freaks
As i am working with light dimmer circuit intrfaced to attiny 45.Using an external interrupt for zcd and delay through one of the GPIO.As per the observation light is flickering @4ms to 10 ms.For 1ms to 3ms of time period light is stable.I am seeing the dimmness between(1ms -10ms)but after 4ms of delay light is flickering more.Can any one guide me to rectify the problem.
#define F_CPU	8000000UL
#include <avr/interrupt.h>
/*****************Function Declaration**********************/
void InitPort(void);
void Extint0(void);
void InitTimer0(void);
void StartTimer0(void);
void Delay(unsigned int );
void InitTimer1(void);
void StartTimer1(void);
void InitPort(void)
		//set PB1 &PB2 as output
		DDRB|=(1<<PB3);  //Delay
		DDRB|=(0<<PB2);  //EXt int
		PORTB|=(1<<PB2);
		PORTB&=~(1<<PB3);
		SREG |= 0x80;
//Initialize Timer0 for 4ms
		//OCR0A = 125;     	//for4ms
		TIMSK|=(1<<OCIE0A);	// enable CTC interrupt
		TCCR0A=0x82;			// Configure timer0 for CTC mode
		TCCR0B|=0x80;			// Start timer at Fcpu /256
		OCR1A=250;				// 250us , with a prescalar of8
		TIMSK|=(1<<OCIE1A);
		TCCR1|=0x80;
void Extint0(void)
	MCUCR|=(0<<ISC00);	    //  logical change on Falling edge INT0 generates an interrupt request.
	MCUCR|=(1<<ISC01);    //  logical change on Falling edge INT0 generates an interrupt request.
	GIMSK|=_BV(INT0);    // Enable INT0*/
	GIFR|=(0<<INTF0);
void Delay(unsigned int n)
		unsigned int i, j;
		for(i=0;i<n;i++)
		for(j=0;j<1000;j++);
ISR(TIMER0_COMPA_vect)
			TCCR0B|=(0<<CS02);  //Timer0 off
			OCR0A=0;
			TCNT0=0;  //Timer0 count to 0
			PORTB|=(1<<PB3);
			TCCR1|=(1<<CS12); //Timer 1 on
	}  //end of ISR
ISR(TIMER1_COMPA_vect)
		PORTB&=~(1<<PB3);
		OCR1A=0;
		TCNT1=0;  //Timer1 count to 0
		TCCR1|=(0<<CS12); //Timer1 off
}  //end of ISR
		InitPort();
		Extint0();
		InitTimer0();
		StartTimer0();
		InitTimer1();
		StartTimer1();
			Delay(1);
ISR(INT0_vect)
	TCCR0B=0x00;
	TCCR0B|=(1<<CS02);  //Enable timer0 on
Welcome to AVRFreaks.
This is (for the moment anyways) a site dedicated to Atmel's AVR products, so your schematic showing a PIC device will cause some confusion. Would you care to tell us what you are really using and provide its schematic please?
Cheers,
Ross
Dear Valusoft,
sorry for the mistaken i have used ATTINY 45 (Not PIC).rest of the components are same.
60 Hz AC has a zero crossing every 8.3 ms. Are you running the avr at 1 Mz or 8 MHz? How about a couple of 'brighter dimmer' buttons?
Hi-
like said bob, control the pulse after zero crossing but see if your triac has enough gate current, if flashing  seam at triac not trigg all the time.
if mosfet, must be wrong timing.
Thierry Pottier
Maybe the load isn't enough to 'hold' the triac? Try a 40 or 60W incandescent light bulb. Don't try a led or fluoro.
Dear Bob,
i am running AVR at  8MHz frequency.AC 230v,50Hz.
Regards
samatha
dear freaks
Thank you for the replies.I am using 60W Bulb as load
How is your code supposed to work? Why the two timers? You should only need 1 timer.
Dear Kartman,
i am using timer0 for delay for (1ms-10ms),and timer1 for to 250us (microseconds)enough to triac has turned on.Kindly guide me how to use 1timer.
Regards
Samatha
You do not have enough gate current
Thierry Pottier
Dear TPE,
can you please guide me to rectify the problem.
cheers
samsan
Google has all your answers. Try avr dimmer
the current gate depand of cadran you are working and triac spec.
show schema with value .
difficult to explain without schema.
if your pulse is 250us it is long enough if current is high enough,
Thierry Pottier
dear TPE
I am using Optocoupler with MOC3021 AND photocoupler  4N35 and TRIAC BT-139 600E.
regards
san
well do not see me a lot , what is the gate drive? do you have enougth current to the MOC. , what sort resistor for the gate?
I guess at the 4N35 is for zero crossing.
Thierry Pottier
by the way, trist to make dimmer with triac today....
My Last project with triac must be 20 years away ( for ligth).
Thierry
Thierry Pottier
Dear TPE,
I am using 670 ohm(1/4watt).
regards
san
ok why do you not share and must ask all the time,.
670R ? where gate? ( if gate it is high enough with 330R - 470R but not out the range. BT139-600E need at least 25mA if T2- G+; max for triac mean 100% trigging but the typical will meat your test lab.)
I think without see your schema, the problem can be on the diode side for MOC.
try to increase the gate pulse 500us and 750us and see if it is some changing,
Thierry Pottier
Dear TPE,
I have increaed gate pulse 500us and  tried with 750us (Timer1
void Extint0(void);
void InitPort(void)
		PORTB|=(1<<PB2);
		PORTB&=~(1<<PB3);
		SREG |= 0x80;
//Initialize Timer0 for 8ms
		OCR0A = 250;     	//for 8ms
		OCR1A=250;				// 500us , with a prescalar of 16
		TIMSK|=(1<<OCIE1A);
		TCCR1|=0x80;
void Extint0(void)
	GIFR|=(0<<INTF0);
		unsigned int i, j;
		for(i=0;i<n;i++)
			OCR0A=0;
			PORTB|=(1<<PB3);
		    TCCR1|=((1<<CS12)|(1<<CS10)); //Timer1 on
	}  //end of ISR
		PORTB&=~(1<<PB3);
		OCR1A=0;
}  //end of ISR
		InitPort();
		Extint0();
		InitTimer0();
		StartTimer0();
		InitTimer1();
		StartTimer1();
			Delay(1);
ISR(INT0_vect)
	TCCR0B=0x00;
) .which is giving more brightness for 8ms delay(Timer0).
Regards
San
ok. well but it was the problem. it is stable?
Thierry Pottier
Dear TPE,
Thank you so much,Yes its stable now.
Regards
san
Dear TPE
Kindly guide me  how to reduce the brightness @8ms without flickering
regards
san
if 50hz and pulse 500us or max 750us than make brigtness to 9,250ms ( if trigger 750us)
Thierry Pottier
Dear TPE,
if 50hz and pulse 500us or max 750us than make brigtness to 9,250ms ( if trigger 750us) ..Can you please elaborate..
Regards
San
one halv periode is 10ms ( 50hz)
minimum brigtness meet if you have less conduction to the triac. that means 10ms - pulse trigger = 9,25ms if pulse trigger is 750us.
Thierry Pottier
Dear TPE
still Bulb is flickering (not continously)but flickering is happening
Regards
San
You need to turn the opto off around 500us before zero crossing to allow the triac to turn off, otherwise it stays on next cycle.
Katman.. well if zero crossing is right , you do not need 500us.
the current in the triac must be higher than hold current to switch on that give you some us after zero crossing . this it is the main EMC problem for heater regulator they wait to long to start the triac after 0V sinus.
but agree with you for a dimmer to have some safe zone and max 9,5ms with end of trigger pulse.
San.
you do  not share all your information.
flickering --> when. just try to increase the max timer and like Katman said, get a safe periode.
I am sure at your schema has some wrong value , pulse drive for the moc or the zero crossing.
I guess you have not scope to control your pulse?
periode of zero crossing, periode of pulse
Thierry Pottier
