is strstr_P() a reentrant function??
10 posts / 0 new
Hi everybody.
I need to find a string inside another string in a ISR. Anybody know if the strstr() or strstr_P() function is reentrant?
Thank you very much.
I'd expect them to be, but so far as I know,
C makes no promises in that regard.
Should not ever call generic lib routines nor do lengthy string work in an ISR. Flag and mark for non-ISR to work on the shared data.
I don't see it using any static memory buffers or anything similar; it should be safe...
http://svn.savannah.nongnu.org/v...
Probably not on mega AVR devices with >64K flash because the RAMPZ register could become altered.
I will consider it is thread safe if it does not use any static memory buffers or anything similar.
One could also just plunk an equivalent source into the ISR and remove doubts about a particular toolchain implementation.
Surely westfw's (2nd) link in post #4 is unequivocal? That is the Asm source of strstr_P. As you can see there is no local state information held in it. It does pretty much exactly what you would expect it to be doing: a sliding compare using LD X+ for the RAm and (E)LPM Z+ for the flash with everything held locally in registers.
EDIT: but is this an "OS" you are talking about or just the simple possibility of an ISR() calling strstr_P while a foreground task was already inside it? If the latter are you sure you want to be doing strstr_P's in an ISR anyway?
I do not have any "OS". I have a ISR calling strstr_P() while a foreground main task occasionally could be inside it. If it in not sure, I can program an equivalent function.
Anybody can ensure that asm code use any global variable? I do not have knowledge about that.
Good point.   I don't think that any of the _P functions mess with RAMPZ, though.  (Which makes using PROGMEM on an Arduino MEGA rather annoying; all the libraries and etc use the _P functions or otherwise assume that flash in the the first 64kwords.
https://github.com/arduino/Ardui... )
