How do I define a lookup table in PROGMEM?
13 posts / 0 new
I am trying to define a lookup table in PROGMEM for an experimental Lisp interpreter on an ATmega328. It needs to consist of a series of strings and function addresses. I've tried this:
const char String1[] PROGMEM = "car";
const object* (*Function1)(object*, object*) PROGMEM = &fn_car;
const char String2[] PROGMEM = "cdr";
const object* (*Function2)(object*, object*) PROGMEM = &fn_cdr;
and so on. The idea is that if the parser encounters "car" it should execute the function fn_car, etc.
However I get the error "variable 'Function1' must be const in order to be put into read-only section". Any suggestions how I should do this?
Cliff addressed that in this earlier thread
https://www.avrfreaks.net/comment...
Thank you - that looks useful.
I'm sure you can find other similar discussions with a determined search.
Shame you hadn't shown us some more context. Anyway this compiles with no warnings/errors:
$ cat avr.c
#include <avr/pgmspace.h>
typedef char object;
const object * fn_car(object * a, object * b);
const object * fn_cdr(object * a, object * b);
const object* (*Function1)(object*, object*) PROGMEM = fn_car;
const object* (*Function2)(object*, object*) PROGMEM = fn_cdr;
const object * fn_car(object * a, object * b) {
const object * fn_cdr(object * a, object * b) {
int main(void) {
I can't help wondering if you meant the function pointer to be "const" not the object* that the functions return? Don't quote me on this but I think this would be the correct placement of the "const" if that's what was intended:
object*  (* const Function1)(object*, object*) PROGMEM = &fn_car;
object* (* const Function2)(object*, object*) PROGMEM = &fn_cdr;
int main(void) {
(again that compilers without warning/error - though just compiling does not prove much!).
Oh and is this C or C++? If it is C then you may want to explore __flash as an alternative to PROGMEM as long as your compiler is beyond 4.6
EDIT: forgot to ask but as the string and the fn-ptr are "joined" wouldn't you consider making them two members of a struct{} instead then just put that whole thing in PROGMEM ?
EDIT2: just realised I was using 4.5.3 where the requirement for PROGMEM data to be "const" was not implemented. So I'm pretty sure that for 4.6+ you must use my 2nd example there. Only you then know if the return of the functions is supposed to be a pointer to const object or perhaps even a const pointer to object?
EDIT3: yup, just checked with 4.9.2 - the first code here has the same error as you encountered, the second one doesn't.
Thank you for the replies. With your help I've got something working, but it's a bit ugly; here's an abbreviated version:
const char String0[] PROGMEM = "car";
const char String1[] PROGMEM = "cdr";
// ... etc
const char* const StringTable[] PROGMEM = {
  String0, String1 // ... etc
typedef void (*f_ptr_type)(void);
const f_ptr_type FunctionTable[] PROGMEM = {
  (f_ptr_type) &fn_car,
  (f_ptr_type) &fn_cdr
// ... etc
object* mylookup(char* n){
  int entry = 0;
  while (entry <= 13) {
    if(strcmp_P(n, (char*)pgm_read_word(&StringTable[entry])) == 0)
      return func((object* (*)(object*, object*))pgm_read_word(&FunctionTable[entry]));
    entry++;
  return NULL;
Here "mylookup" is called with a string, such as "car", and it returns a cell constructed by the call to "func" containing the function address.
Any suggestions of how to make it a bit more elegant would be appreciated.
As I say, as the string and the function pointer are "joined" I would make that link and actually join them (a struct). So something like this where I've also wrapped enough around it to make it compilable:
typedef object *(*f_ptr_type)(object *, object *);
typedef struct {
    const char * string;
    f_ptr_type fptr;
} tbl_entry_t;
object * fn_add(object * a, object * b) {
// ... etc
const tbl_entry_t lookup[] PROGMEM = {
    { String0, fn_car },
    { String1, fn_cdr }
    // etc.
object * func(f_ptr_type fp) {
  int entry = 0;
    if(strcmp_P(n, (char*)pgm_read_word(&lookup[entry].string)) == 0)
      return func((f_ptr_type)pgm_read_word(&lookup[entry].fptr));
    entry++;
  return func(fn_add);
int main(void) {
That compiles without warning/error. No guarantees it actually does what you intended though! The key thing though is this:
    { String1, fn_cdr }
    // etc.
which combines string+function pointer into single entities.
BTW in doing this I noticed you had:
that is too simplistic. No wonder you needed convoluted typecasts. It needs to be:
That's much better than my version, thank you.
I guess the proof of the pudding is whether it actually does what it is supposed to.
It works!
Next (as this is "new" code you appear to be authoring) you should look at ditching PROGMEM in favour of the recently added __flash so you won't need the pgm_read_*() dereferences. Untried but something like the following...
Again this compiles cleanly but I don't know if it actually works (and you need a "late" compiler like a 4.8.1 or 4.9.2 or even later):
typedef struct {
    const __flash char * string;
    f_ptr_type fptr;
} tbl_entry_t;
const __flash char String0[] = "car";
const __flash char String1[] = "cdr";
// ... etc
const __flash tbl_entry_t lookup[] = {
    { String1, fn_cdr }
    // etc.
  int entry = 0;
    if(strcmp_P(n, (char*)lookup[entry].string) == 0)
      return func(lookup[entry].fptr);
    entry++;
int main(void) {
While the pgm_read_*() stuff is removed (makes things look much cleaner!) you still need <avr/pgmspace.h> for the prototype to strcmp_P().
Thank you - that's definitely tidier. I may try that when everything else is working.
Thanks for all your help; here's what I needed it for:
www.ulisp.com
