Pretty much all modern networks have a DHCP server somewhere. When an ethernet device first connects to a network to set up an IP link it sends broadcats to 255.255.255.255 which the DHCP server will process and issue it the next available IP from a local pool of subnet addresses often 192.168.0.x. In this case the gateway would almost certainly be 192168.01 and this is one of the things passed to the DHCP client when it is issued the IP address. So your local machine should be able to tell you the IP of the gateway that was retrieved during this process.
On the other hand it IS possible to set up a network with static/fixed IP where they are just assigned manually but surely your local PC network isn't like this?
A thing that commonly happens is that if you add some very dumb devices to the network (the kind of thing made with an AVR in fact) they won't have the brains to do DHCP so they must be given static/fixed IP addresses but they still need to be in the local subnet range. For example at home I have a couple of IP cameras I just picked 192.168.0.235 and 192.168.0.241 for on the basis that it was unlikely my router's DHCP would ever actually issue these addresses. Though you have to be careful on larger networks that you might accidentally set a fixed IP that was then assigned automatically by DHCP .
Because I changed my ip setting for something else and I have reset it..
But then, again, for heaven's sake, and just to show us that you are in fact capable of logical arguing...
DON'T CHANGE ANYTHING AT YOUR PC AND DO 2 TESTS WITH YOUR 2 BOARDS AND TELL IF THERE'S A DIFFERENT RESULT. Is it that difficult to arrive at a certain form of intelligent problem analysis?
Einstein was right: "Two things are unlimited: the universe and the human stupidity. But i'm not quite sure about the former..."
ErrataAn errata sheet, describing minor operational differences from the data sheet and recommended workarounds, may exist for currentdevices. As device/documentation issues become known to us, we will publish an errata sheet. The errata will specify the revisionof silicon and revision of document to which it applies.To determine if an errata sheet exists for a particular device, please check with one of the following:•Microchip’s Worldwide Web site; http://www.microchip.com•Your local Microchip sales office (see last page)When contacting a sales office, please specify which device, revision of silicon and data sheet (include literature number) you areusing.Customer Notification System
You keep asking us questions assuming we know exactly what compiler etc. You have told us very little. Do you do this to waste our time or are you just clueless? I think we're past three years already - how much longer will this go on for?
This syntax assumes you have something using a struct def with bit fields to name the bits b0..b7. Do you have/use such a thing? If not stick to standard C notation.
only works if "dest" has been defined as a struct of 1 bit length bit fields called b0..b7
Anyway looking at your question above again:
#define ENC28J60_CONTROL_CS DDR_B.b4
#define ENC28J60_CONTROL_DDR DDRB
ENC28J60_CONTROL_DDR |= 1<<ENC28J60_CONTROL_CS;
this just looks like utter nonsense. Try expanding out the macros here and you would be looking at:
DDRB |= 1 << DDR_B.b4
given that the purpose of DDR_B.b4 is presumably to make a single bit in DDR settable using 0 and 1 then the only possible values of DDR_B.b4 would be 0 or 1 and thus this line can only mean:
DDRB |= 1 << 0
or
DDRB |= 1 << 1
So if the intention is to set bit 4 why would you use something that only sets bit 1 or bit 0. Utter nonsense.
To be frank your current understanding and programming skills just aren't up to a job like doing TCP/IP using an ENC28J60. You need to learn some basic C before you can attempt something that complex. Sorry to be brutal but it's a sad fact and just "guessing at stuff" is not going to write sensible C code for you and especially not for something as complex as Ethernet chips.
if you just want an AVR to connect to the internet why not get an Ethernet shield on an Arduino or something much simpler like that?
first thing I want to know, what's the ID of this ENC28J60, because Kartman suggest seeing errata....different revision different treatment, there's a possibility I'm using different chip with my previous experiment...
If your spi is not good, what is the point of tryingvto get the id? Fix one problem at a time and don't try sucking up to us - you've been at this game for a few years now so get some self respect.
DDRB |= 1 << 0
or
DDRB |= 1 << 1
So how do u suggest me writing the definition? Thanks
Doesn't matter...there s a probability I will get stuck with arduino as well... right? No guarantee it will work n i return to the avr chip finally... no different... ..
It's all about narrowing down the possibilities. Most people can't cope when there is more than one problem and you most likely have a number of probably small defects that conspire to make the problem intractable. Since you don't give us much information, we have a real hard time trying to help. But I've been through all this before over the years and you're still not getting it. There's no magic in this stuff - just a bit or work. Who do you think sorts out my technical problems? I've got a few at the moment that aren't going to magically solve themselves - I actually have to do some work.
I ll give a test only one chip atmega with logic analyzer n test_port function... @kartman how do u reckon of my spi register setting? This enc28.. from I hv read... some versions sensitive with SCK speed..
And I don t know which one I hv... can not read its id yet...
I used to do php n JavaScript with linux before r u using embedded linux? I read at glance this morning about freescale... actually i wanna know.. any cheap freescale board that i can buy n play with it?
the current work is cloud based. Linux, embedded linux,bare metal,rtos, I do it all. Sometimes all in one day.
" actually i wanna know.. any cheap freescale board that i can buy n play with it?" that's the sort of question that annoys me. Freescale/nxp make a stupid amount of different processors - you can easily Google what they are offering and find out the price - so why ask such a question? You've got a STM32F4 board, so that is similar to the higher end parts of the Kinetis range. Personally, I prefer STM32 parts as the peripherals are a bit more sensible than the Kinetis.
That picture is meaningless to me. All I can see is activity - but not what that activity entails. I could suggest that there is no short circuits, but that's about all.
How does the definition of PORTB4 look like? Is it a bit number (which would be correct) or a bit mask (which would be wrong)?
And please: if you don't know the difference, ultimately stop playing with MCUs and programming and do something more adhering to your likes and capabilities.
Please don't tell me what to do or what I LIKE to do, and speak about my capability, I"m learning, so if you're the MASTER tell me then....
DO NOT critize only but not even helping....thank you very much...if you're not interested on reading, pass it...easier...don't even click the topic....WHO ask you to click it anyway...NOT ME..
I try getting 8MHz SPI but I get 4MHz in logic analyzer
I agree that if people don't have anything to say that will help they simply should not say it.
Having said that I do think you have to recognise that you evidently are attempting something that appears to be beyond your current skillset and the only way to remedy that is to expand your skillset (ie learn more about C programming and things like Ethernet, TCP/IP and so on) before attempting to continue. Otherwise it's just like bubbles under the wallpaper. You may fix one of your problems in one place just to have others pop up elsewhere.
What I DO NOT understand.....it was working ok without a problem, now with the same board and the same code...I DO NOT change anything and IT IS NOT WORKING....really ridicilus for me...
despite of I"m capable on making it or not.... you don't have to judge like you're my MASTER or my TEACHER or already VERY GOOD IN C .....are you my MASTER ?? WHAT'S THE POINT I'M JOINING THE FORUM IF I CAN NOT ASK.... ?? that's really strange for me....
THAT IS WHY, I HAVE A QUESTION....if you have the situation like this....what do you have in your mind ?
I get 8MHz on SPI, get response from EN28J60...I keep trying....
We don't understand either because you haven't given us enough information. Maybe you think we magically solve problems given zero information. For years we've been telling you the same thing, but you don't listen.
So feel free to go elsewhere if you don't like the service, but i'd suggest the root cause is closer to home.
What s the IP for default gateway if I use switch?
TopPretty much all modern networks have a DHCP server somewhere. When an ethernet device first connects to a network to set up an IP link it sends broadcats to 255.255.255.255 which the DHCP server will process and issue it the next available IP from a local pool of subnet addresses often 192.168.0.x. In this case the gateway would almost certainly be 192168.01 and this is one of the things passed to the DHCP client when it is issued the IP address. So your local machine should be able to tell you the IP of the gateway that was retrieved during this process.
TopBut then, again, for heaven's sake, and just to show us that you are in fact capable of logical arguing...
TopGuys - you're being trolled.
TopAlways got accused as a troller....that's ok....fine with me...
TopDON'T CHANGE ANYTHING AT YOUR PC AND DO 2 TESTS WITH YOUR 2 BOARDS AND TELL IF THERE'S A DIFFERENT RESULT ,
Ok, I'll start with working board before and nothing in my computer, my wifi is 10.0.0.3 and I have two interfaces in my computer....LAN and wifi...
I don't know what to do with LAN....I can connect to switch or cross cable to the board
What should I do with this :
TopI 'm trying now with :
My board Ip is 10.0.0.20
TopWas working :
TopIs this a clue ?
26 1.737808 QuantaCo_71:47:e0 Broadcast ARP 42 Who has 184.86.223.195? Tell 10.0.0.2 ....is it pointing to my board ?
TopIs your board named Akamai?
TopI tried to debug here :
Result :
ENC28J60 Test application!
ENC28J60 Initialization finished!
MAC ADDR 0:
00
ENC28J60 init!
BEFORE WHILE
Why MAC = 00 ?
Init code :
Any knowledge ?
Thanks for concerning.....
TopLook in the eratta for the enc28j60.
TopWht should I give attention at errata? Tx
TopErrataAn errata sheet, describing minor operational differences from the data sheet and recommended workarounds, may exist for currentdevices. As device/documentation issues become known to us, we will publish an errata sheet. The errata will specify the revisionof silicon and revision of document to which it applies.To determine if an errata sheet exists for a particular device, please check with one of the following:•Microchip’s Worldwide Web site; http://www.microchip.com•Your local Microchip sales office (see last page)When contacting a sales office, please specify which device, revision of silicon and data sheet (include literature number) you areusing.Customer Notification System
TopThat one? Probably my chip has different version? Let me see
http://ww1.microchip.com/downloa...
How do I know which chip I have with which errata ?
TopIs ENC28J60_CONTROL_DDR |= 1<<ENC28J60_CONTROL_CS; equal with DDRB = 0x10; ?
I tried to get EREVID but got 0000, what do I miss here ?
TopAre you REALLY trying to tell us that you are not able to see if a 1 shifted left by 4 is or is not equal to 0x10?
What about playing with marbels or reading a comic?
TopAbit confuse with shifting logic ...
I made
#define ENC28J60_CONTROL_CS PORT_B.b4
is it equal to DDRB = 0x10, I want to activate DDRB bit 4 as output, but confuse with the define,
or
TopYou keep asking us questions assuming we know exactly what compiler etc. You have told us very little. Do you do this to waste our time or are you just clueless? I think we're past three years already - how much longer will this go on for?
TopI'm using Atmel Studio 6...Please correct me if I'm wrong with those define statement...tx
TopThis syntax assumes you have something using a struct def with bit fields to name the bits b0..b7. Do you have/use such a thing? If not stick to standard C notation.
TopWhat's the standard one ?
here's what I have :
// structure to allow bit field operations, name conversions: PORTA.0 -> PORT_A.b0 PORTB.7 -> PORT_B.b7
typedef struct{ uint8_t b0:1;
uint8_t b1:1;
uint8_t b2:1;
uint8_t b3:1;
uint8_t b4:1;
uint8_t b5:1;
uint8_t b6:1;
uint8_t b7:1; } bits;
TopYou have a logic analyser that you could use to confirm this in seconds.
TopThis works in every C compiler on earth:
while:
DDRB |= 1 << 0
or
DDRB |= 1 << 1
Topwell, more BASIC than C, i guess! :-)
Sorry, couldn't resist...
TopYup I will learn more basic than C.....not a problem, life is learning for me....and you guys will give me some lessons...that would be good...
that's the point I'm joining this forum, LEARNING....
I'll make like this then ..
DDRB =0x16; //PB4 = CS, PB1= MOSI OUT, PB2 = SCK OUT, PB3 = MISO IN
Topand from logic analyzer....the output is not good...I do not understand....
I'm using a library and it was working before....that's why I have a question ??? Is the library stable or just another C experiment ??
Is it because I share SPI port with some chips ? or between 3.3V and 5V ?
Have a look on logic analyzer.....very bad....that's the chip talking to me....not in any languages only 0 and 1.....not C....
TopTEST code with low level beginner BASIC C,
any suggestions or corrections from MASTER of C language ?
TopIf your spi is not good, what is the point of tryingvto get the id? Fix one problem at a time and don't try sucking up to us - you've been at this game for a few years now so get some self respect.
TopSorry if u are felt being sucked....that s ur own thinking... like I said I learn...learning is different with sucking...
TopSo how do u suggest me writing the definition? Thanks
Topif you just want an AVR to connect to the internet why not get an Ethernet shield on an Arduino or something much simpler like that?
TopIt's all about narrowing down the possibilities. Most people can't cope when there is more than one problem and you most likely have a number of probably small defects that conspire to make the problem intractable. Since you don't give us much information, we have a real hard time trying to help. But I've been through all this before over the years and you're still not getting it. There's no magic in this stuff - just a bit or work. Who do you think sorts out my technical problems? I've got a few at the moment that aren't going to magically solve themselves - I actually have to do some work.
TopI ll give a test only one chip atmega with logic analyzer n test_port function... @kartman how do u reckon of my spi register setting? This enc28.. from I hv read... some versions sensitive with SCK speed..
Anyway thx for concerning.
Top@kartkan Good luck for ur work... may I know... what series do u use? Mega ..sam?
TopI think I m not good on explaining my issue.... sorry if it s making u guys annoyed
TopI use freescale/nxp at the office, but I'm doing web stuff at the moment in php/javascript.
TopI used to do php n JavaScript with linux before r u using embedded linux? I read at glance this morning about freescale... actually i wanna know.. any cheap freescale board that i can buy n play with it?
Topthe current work is cloud based. Linux, embedded linux,bare metal,rtos, I do it all. Sometimes all in one day.
TopPlease correct me if I'm wrong :
TopI got something on SPI but I haven't tested for complete REVID....
DDRB = 0xB7;
TopThat picture is meaningless to me. All I can see is activity - but not what that activity entails. I could suggest that there is no short circuits, but that's about all.
TopHow does the definition of PORTB4 look like? Is it a bit number (which would be correct) or a bit mask (which would be wrong)?
likes andcapabilities.Einstein was right: "Two things are unlimited: the universe and the human stupidity. But i'm not quite sure about the former..."
TopPlease don't tell me what to do or what I LIKE to do, and speak about my capability, I"m learning, so if you're the MASTER tell me then....
Have a look....if you don't know the answer just silence...a lot easier, than speak up but saying something useless...
TopI read from :
http://easyelectronics.ru/img/Mo...
page 3....
oo....my fastest SPI on atmega is 8MHz....can I overclock it to 25MHz on its crystal ?
1. Module: MAC Interface
When the SPI clock from the host microcontroller
is run at frequencies of less than 8 MHz, reading or
writing to the MAC registers may be unreliable.
TopI agree that if people don't have anything to say that will help they simply should not say it.
Moderator
TopWhat I DO NOT understand.....it was working ok without a problem, now with the same board and the same code...I DO NOT change anything and IT IS NOT WORKING....really ridicilus for me...
TopWe don't understand either because you haven't given us enough information. Maybe you think we magically solve problems given zero information. For years we've been telling you the same thing, but you don't listen.
TopWhat information do u need?
TopToo late. You've burnt this bridge.
TopPages
