Hi
This power supply is 3w and its small in size.
I want to build something like this.
Size matter to me
What topology should I use for such small power supply?
Hi
Size matter to me
It's most likely a flyback converter.
from phase it going to diode half rectifier first then to rest of circuit
maybe i should reverse engineer it
Maybe you should. There's not many components. The secret is in the design of the transformer.
How does it work? Nicely.
https://en.m.wikipedia.org/wiki/Flyback_converter
I had to look it up.
Yes, but it could also just be a simple stepdown transformer and a linear regulator, (e.g. 7805).
What does the 3-lead device that looks like a transistor say on it?
When you talk about power supplies it would be helpful to know, at a minimum:
Vin
Vout
current requirement
Other factors can come into play but those are the main ones.
Doc, the core is not big enough for 3W at 110VAC/60Hz. Being ferrite, even more so.
From the size of it, it's definitely switching.
The case in the picture clearly states 220/240 ac, I would assume 50hz.
Looks like a flyback with weak regulation.
Power Integrations offers nice suite for supply design. PI chips have nice protection features. IMHO easier and safer than discrete based solution. Used in a number of appliances built -ins and instruments.
