Using a LED driver to provide PWM signals
4 posts / 0 new
Hey guys,
I have a need to generate 16 pwm signals, but just at regular logic levels.  I want to use I2C to control it so was looking at a TLC59116 as a possibility (data sheet here).  My question is, can I just add pull-up resisters to the outputs to convert it to logic levels and if so what value resistor should I use?
Cheers
Simon
You really need to post what you are going to be hooking up to the outputs. Will it be a TTL chip or some motor driver chips? On that, it all depends. Off the cuff, I would say 10K resistors will do the trick.
Thanks for the reply.  Sorry, yes I should have.  It is just going to be logic pins on another cmos ic.  I should probably have also mentioned it would be a 3.3V supply.
Cheers
Simon
I'm sitting here imagining a machine with 16 motors that need speed control only, no position or direction sense. Maybe a wind chime hammer? Anyway, if the pwm is used for led brightness, the ws2812 rgb leds at adafruit are the bomb.
