Attiny84 does not enter interrupt
12 posts / 0 new
Hi, my purpose is to use external interrupt pin. I hooked up button to PB2 in Attiny84, although ı press button led doesn't
turn on where is the mistake?
#define F_CPU 1000000UL
#include <avr/interrupt.h>
#include <util/delay.h>
#include <stdio.h>
ISR(INT0_vect);
void interupt_init();
ISR(INT0_vect){
	PORTA|=(1<<7);
void interupt_init(){
	MCUCR=(1<<ISC01)|(1<<ISC00); // rising edge
	GIMSK=(1<<INT0);
	sei();
int main(void){
	DDRA=0X80;
	interupt_init();
        while(1);
	return 0;
What warnings or errors do you get when doing a clean build?
Greg Muth
Portland, OR, US
Make Xmega Great Again!
Pull-up?
Show how you've wired up your button.  And your LED.  Are you sure it isn't backwards?
A schematic is best.
Build: 1 succeeded or up-to-date, 0 failed, 0 skipped,
Tell how you expect to get a rising edge out of that schematic.  (with pullup enabled or not...)  I guess it is possible if the --|> symbol represents Vcc.  It looks like chassis ground to me.
 --|> this symbol represents +5v in proteus, when ı click clean solution it gave Build succeeded.
========== Clean: 1 succeeded, 0 failed, 0 skipped ==========
theusch wrote:
Greg_Muth wrote: What warnings or errors do you get when doing a clean build?
Proteus?  So we aren't concerned with a real app here?  What voltage is on PB2 when the button is pressed?  What voltage is on PB2 when the button is released?  Without Vcc or Gnd connections to your micro, will it run at all?
Simulate the code and see where it goes wrong.
Did you try LED of another color? Blue LED-s have high voltage drop. Maybe your code works correctly, but the LED current is so low so you can't see its light.
What is Vcc value? Maybe it's too low for blue LED?
ı tried to turn on led with another code in this circuit and ı could turn it on, there is no problem proteus schematic, voltage setting etc..
ı solved problem, my compiler is Atmel Studio 6.0 ı've selected Attiny84A, ı changed it's name by being Attiny84 and problem vanished...
