why the output of sprintf is like this?
8 posts / 0 new
hi
i have this
unsigned char *ATC = "mychar=" ;
int myvalue =1  ;
char temp[11];
sprintf(temp , "%s%d " , ATC , myvalue);
and the temp will be "mychar=11"
i want it to be "mychar=1"
Here is a sprintf reference: http://www.tutorialspoint.com/c_... but that's not where your problem is. You never set myvalue to anything.
From another thread you started:
ki0bk wrote:
There is a sticky at the start of the forum that explains how to ask good questions so you can get good answers.
I dont know how should i ask that everyone like
Is these q is so hard that want more explain?
All input and output is right here what else do u want?
Your question looks fine to me.
Your code looks fine to me.
I am intrigued. Please post your complete compilable code. i.e. a minimal source that shows this behaviour.
Or just ZIP up your AS7 project and attach it.
One handy trick in this situation is to add a space or # character after your %d.
I also recommend that you use a better name than temp. How about buffer?
And that you make it big enough to accept any int e.g. -12345
navidrct wrote:
I dont know how should i ask that everyone like Is these q is so hard that want more explain? All input and output is right here what else do u want?
Well, I don't know what to say. Your original code as posted:
int myvalue = ;  <---- This is your problem
char temp[11];
You never set myvalue to anything, it should be 0 but you said it returns 11. Then you went back and edited the code to myvalue = 1, but you still claim myvalue contains 11. What's to understand? Sorry, you are not posting working code. You are making code up and posting it untested. That's the problem. Listen to david.prentice. I'm out of here.
david.prentice wrote:
Your question looks fine to me. Your code looks fine to me. . I am intrigued. Please post your complete compilable code. i.e. a minimal source that shows this behaviour. Or just ZIP up your AS7 project and attach it. . One handy trick in this situation is to add a space or # character after your %d. I also recommend that you use a better name than temp. How about buffer? And that you make it big enough to accept any int e.g. -12345
thanks very much
ill test it
char temp[11];
i did test my code
thank you
solved
thanks everyone
Late to this thread but:
int myvalue =1  ;
char temp[11];
What on earth is the point of "ATC" in this anyway? Why not simply:
int myvalue =1  ;
char temp[11];
sprintf(temp , "mychar=%d " , myvalue);
By the way [11] is not enough; myvalue could, potentially be -32768 in which case the string is "mychar=-32768". That is 13 characters already and with the "hidden" terminating 0x00 at the end it is really 14 bytes. So I suggest temp[] needs to be [14].
