Using static and volatile
2 posts / 0 new
I have some questions about static and volatile keywords.
I understand static is normally used inside functions to keep the value in memory and volatile is used if theres some interrupt that would change the value outside the function.
So what I don't undestand is what does the static keyword do in the following,
static volatile unsigned char test;
void somefunction(void)
     test++;
If test is declared as attribute, it already keeps the value in memory so what's the point?
And the second question,
    test++;
In which case does the test variable have to be volatile?
These are standard 'C' keywords - nothing specifically to do with GCC or the AVR - so you should start with a good 'C' textbook!
K&R would be an ideal reference:
http://www.amazon.co.uk/exec/obi...
That is one use of static; the other is outside functions, where it restricts the identifier's "scope" to just the current compilation unit.
(strictly, it forces internal linkage)
Again, that's just one application of volatile.
volatile advises the compiler that the object may be subject to change by some means not visible to it and, therefore, that it must not apply any optimisation that assumes otherwise.
Other common uses of volatile would be in multi-tasking systems, in shared memory, and in memory-mapped IO.
Volatile may also be needed to prevent a compiler from optimising-out software delay loops.
Hopefully, that should explain your questions?
