But I don't seem to be able to get this to work. I'm helping someone port their Arduino code and I'm 99% of the way there. I'm using the Fleury library. It's just a simple reading of a IMU. I get the yellow led's to start and it never gets past the first check read.
i2c_start_wait(imu+I2C_WRITE); // set device address and write mode
i2c_write(0x00); // write address for x valuelow
between these two lines is where it locks up.
This is my first try in I2C
Note: I'm sure there are tons of issues in this code, but right now my main priority is actually reading the IMU...
#define F_CPU 16000000UL #include<avr/interrupt.h> #include <util/delay.h> #include <math.h> #include <stdlib.h> extern "C" { #include "lib/light_ws2812.h" #include "lib\i2cmaster.h" } #define ledsize 4 int ledvalue = 50; struct cRGB led[ledsize]; #define imu 0x53 volatile float delaysensevalue = 0; volatile int sensoroffsetroutine = 1; volatile float sensoroffset = 0; #define filteredsensorvalue (xvalue - sensoroffset) #define ledvalue ((xvalue + sensoroffset)*20) volatile int delayvalue (delaysensevalue); volatile int pwmvalue=1; volatile int patternselectorarray[5] = {1,2,3,4,5}; //was a good idea but not cleanly implemented. maybe later volatile float xvalue = 0; volatile float yvalue = 0; volatile char datareturn = 0; //////////////////////////////////////////////////////////////////////////////////////////////////////// //Functions //////////////////////////////////////////////////////////////////////////////////////////////////////// void delay(int delayvalue) { for (int i = 0; i<=delayvalue; i++) { _delay_ms(1); } } void setupimuint() { i2c_start(imu+I2C_WRITE); //start write process i2c_write(0x24); //set thresh act i2c_write(0b00000001); // ret=0 -> Ok, ret=1 -> no ACK i2c_stop(); i2c_start(imu+I2C_WRITE); //start write process i2c_write(0x27); //set act -z bit i2c_write(0b10000000); // ret=0 -> Ok, ret=1 -> no ACK i2c_stop(); i2c_start(imu+I2C_WRITE); //start write process i2c_write(0x2E); //set act z enable i2c_write(0b00010000); // ret=0 -> Ok, ret=1 -> no ACK i2c_stop(); i2c_start(imu+I2C_WRITE); //start write process i2c_write(0x2F); //set map z to int1 i2c_write(0b00010000); // ret=0 -> Ok, ret=1 -> no ACK i2c_stop(); // set stop conditon = release bus } ////////////////////////////////////////////////////////////////////////////////////// void interruptroutine() { while (PIND & PIND2) { // pattern1(); //pattern2(); //pattern3(); //pattern4(); //pattern5(); } } /////////////////////////////////////////////////////////////////////////////////////// void setupAVRint() { DDRD &= (~(1<<DD2)); EICRA |= 1<<ISC20; EICRA |= 1<<ISC21; EIMSK |= 1<<INT2; sei(); } /////////////////////////////////////////////////////////////////////////////////////// void setupimu() { _delay_ms(500); i2c_start_wait(imu+I2C_WRITE); // set device address and write mode i2c_write(0x00); // write address for x valuelow i2c_rep_start(imu+I2C_READ); // set device address and read mode datareturn = i2c_readNak(); // read one byte from EEPROM i2c_stop(); if (!(datareturn = imu)) { while(1) { //flashred(); } } } ////////////////////////////////////////////////////////////////////////////////// void readimu() { i2c_start_wait(imu+I2C_WRITE); // set device address and write mode i2c_write(0x05); // write address for x valuelow i2c_rep_start(imu+I2C_READ); // set device address and read mode datareturn = i2c_readNak(); // read one byte from EEPROM i2c_stop(); xvalue = datareturn; i2c_start_wait(imu+I2C_WRITE); // set device address and write mode i2c_write(0x05); // write address for x valuehigh i2c_rep_start(imu+I2C_READ); // set device address and read mode datareturn = i2c_readNak(); // read one byte from EEPROM i2c_stop(); xvalue = xvalue + datareturn; i2c_start_wait(imu+I2C_WRITE); // set device address and write mode i2c_write(0x05); // write address for y valuelow i2c_rep_start(imu+I2C_READ); // set device address and read mode datareturn = i2c_readNak(); // read one byte from EEPROM i2c_stop(); yvalue = datareturn; i2c_start_wait(imu+I2C_WRITE); // set device address and write mode i2c_write(0x05); // write address for y valuehigh i2c_rep_start(imu+I2C_READ); // set device address and read mode datareturn = i2c_readNak(); // read one byte from EEPROM i2c_stop(); yvalue = yvalue + datareturn; } ///////////////////////////////////////////////////////////////////////////// ///////////////////////////////////////////////////////////////////////////////////////////////////// //Flash patterns //////////////////////////////////////////////////////////////////////////////////////////////////// void flashred() { for (int i=0; i<ledsize; i++) { led[i].r=ledvalue;led[i].g=0;led[i].b=0; ws2812_setleds(led,ledsize); } _delay_ms(200); for (int i=0; i<ledsize; i++) { led[i].r=0;led[i].g=0;led[i].b=0; ws2812_setleds(led,ledsize); } _delay_ms(200); } //////////////////////////////////////////////////////////////////////////////////////////////////// void nomovementpulse() { for(double i=5; i<255; i=i*1.02) { _delay_ms(5); pwmvalue = i; for (int x = 0; x<ledsize; x++) { led[x].r=0;led[x].g=pwmvalue;led[x].b=0; ws2812_setleds(led,ledsize); } } for(double i=255; i>5; i=i/1.02) { _delay_ms(15); pwmvalue = i; for (int x = 0; x<ledsize; x++) { led[x].r=0;led[x].g=pwmvalue;led[x].b=0; ws2812_setleds(led,ledsize); } } } ///////////////////////////////////////////////////////////////////////////////////////////////////// void pattern1() { // pattern 1 readimu(); for(int i = 0; i<ledsize; i++) { led[i].r= abs(ledvalue*2);led[i].g=0;led[i].b=abs(ledvalue/2); } ws2812_setleds(led,ledsize); delay(abs(delaysensevalue)); for(int i = 0; i<ledsize; i++) { led[i].r=255;led[i].g=0;led[i].b=0; } ws2812_setleds(led,ledsize); delay(abs(delaysensevalue)); } /////////////////////////////////////////////////////////////////////////////////////////////////////// void pattern2() { // pattern 2 for(int i = 0; i<ledsize; i++) { readimu(); led[i].r=abs(ledvalue*2);led[i].g=0;led[i].b=abs(ledvalue/2); ws2812_setleds(led,ledsize); delay(abs(delaysensevalue)); } for(int i = 0; i<ledsize; i++) { readimu(); led[i].r=255;led[i].g=0;led[i].b=0; ws2812_setleds(led,ledsize); delay(abs(delaysensevalue)); } } ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// void pattern3() { // pattern 3 readimu(); for(int i = 0; i<ledsize; i++) { led[i].r=abs(ledvalue*2);led[i].g=0;led[i].b=abs(ledvalue/2); } ws2812_setleds(led,ledsize); delay(10); } /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// void pattern4() { readimu(); // pattern 4 for(int i = 0; i<ledsize; i++) { led[i].r=abs(ledvalue*2);led[i].g=0;led[i].b=abs(ledvalue/2); ws2812_setleds(led,ledsize); delay(abs(delaysensevalue)); } } ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// //Sketch start ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// ///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// int main(void) { i2c_init(); for(int i=0; i<ledsize; i++) // sets leds yellow while the imu starts { led[i].r=pwmvalue;led[i].g=pwmvalue;led[i].b=0; } ws2812_setleds(led,ledsize); _delay_ms(200); setupimu(); setupimuint(); //sets up interrupt for activity on int1 If you have already run this specific IMU you can remove this to start faster setupAVRint(); for(int i=0; i<ledsize; i++) // sets leds green when IMU is all set up { led[i].r=0;led[i].g=pwmvalue;led[i].b=0; } ws2812_setleds(led,ledsize); _delay_ms(2000); while (1) { nomovementpulse(); } } ISR (INT2_vect) { while (PIND & PIND2) { for(int i=0; i<ledsize; i++) { led[i].r=0;led[i].g=0;led[i].b=pwmvalue; } ws2812_setleds(led,ledsize); } }
