Enabling and servicing TC interrupts on SAM
2 posts / 0 new
Hi there,
I am trying to implement a timer counter interrupt in the SAMV71 (using the Xplained board) and having trouble making it hit the ISR. I am porting code from an AVR32 so I'm following a similar process but I think I'm missing something ARM specific. Here is what I have done:
1. Enabled the global and peripheral specific interrupt:
void interrupt_setup(void) {
    Disable_global_interrupt();
    NVIC_ClearPendingIRQ(TC0_IRQn);
    NVIC_EnableIRQ(TC0_IRQn);
    Enable_global_interrupt();
2. Implemented the ISR:
void TC0_Handler(void) {
    test = 1;    // dummy global variable (breakpoint at this line)
3. Enabled all TC0 interrupts (just to be sure):
TC0->TC_CHANNEL[0].TC_IER = 0xFF;
This all compiles and programs fine, but I run the program and it never hits the ISR. The TC value is definitely enabled and running.
Does anyone have any ideas about what I'm doing wrong here?
It seems to be working if I strip out the rest of my code which is unrelated to the timer, so I'll work from there. However, if I set a breakpoint at the start of TC0_Handler the value of TC_CV0 is completely random between 0 and TC_RC0. I expect it to be either RC0 or just above zero (as the timer resets at RC0). Why would this be so?
