Dear friends
Hi and good day
I have never used a CT yet and now im going to use the AC1030 CT which I have attached the datasheet .the aim is to use the ct in an energy meter (AC current measure)
I have some question about it .
1- it has used a 100 ohm resistor in the output , can I use other resistors too ? for example a 10 ohm ?
2- how can I change the voltage which I read from the micro controller (adc) to the real current ?
3-does it have a logarytmic pattern (As I see in the voltage -current figure or it is linear ? (could you please tell me the exact way via example)
regards
