Debug programmed code without loading new code.
4 posts / 0 new
I'm trying to debug an issue that I'm pretty sure is a result of having a wrong (inconsistent) value of a symbolic constant defined.
The relevant code is:
#define TRIGGER_ADDR {0xe7,0xE8, 0xD7, 0xD5, 0xAF};
uint8_t trigger_addr[5] =  TRIGGER_ADDR;
The value of TRIGGER_ADDR is different for every unique chip.  I want to know what's programmed in a specific chip, using the Atmel ICE and Studio 6.
Is it possible?
When I debug using debugwire, I know Studio first reprograms the device.
I don't know where to look for assembly code that initializes the global array trigger_addr or how to use the .lss, .map, or other compiler generated file to figure out the memory location of the trigger_addr[5] array.  Maybe if I could figure that out, I use the Studio 6 debugger to figure out what's being loaded to that address?
Or, is there no way to use Studio 6 and Atmel Ice to debug without first clobbering whatever has previously been programmed?
Thanks!
:: Morten
Was just going to post that I figured out attach works, then do a reset.
Thanks!
Wow, never noticed that! Could have used it dozens of times in the last few months.
Thanks, Morten
