WiFi WILC1000 SAMA5D3 Xplained firmware load issue
2 posts / 0 new
I'm testing a ATWILC1000-MR110PB demo board on SAMA5D3 Xplained evaluation platform. After running precompiled linux and filesytem image named "wilc1000_with_sama5d3_xplaind_linux-on_3.18" got from local Atmel distributor, I want to try the latest  ATWILC1000 driver dowloaded from internet site /wireless-driver. The issue is that I cant get the firmware loaded, here kernel message:
modprobe wilc1000.ko
IN INIT FUNCTION
*** WILC1000 driver VERSION=[14.0.1] REVISON=[249] FW_VER=[14.0.1] ***
Driver Initializing success
conf &buildroot ~]# wpa_supplicant -Dnl80211 -iwlan0 -c/etc/wilc_wpa_supplicant. [1] 699
[root@buildroot ~]# Successfully initialized wpa_supplicant
rfkill: Cannot open RFKILL control device
loading firmware atmel/wilc1003_firmware.bin
ERR [repeat_power_cycle: 1938]Failed to start firmware
ERR [wilc1000_wlan_init: 2029]Failed to start firmware
ERR [wilc_wlan_cleanup: 2020]Writing ABORT reg
ERR [wilc1000_wlan_init: 2080]WLAN Iinitialization FAILED
ERR [mac_open: 2154]Failed to initialize wilc1000
[Sendconfigpkt]Set Timed out
ERR [Handle_SetWfiDrvHandler: 706]Failed to set driver handler
ERR [Handle_SetWfiDrvHandler: 707]PRINT_ER(-103)
Could not set interface wlan0 flags (UP): Input/output error
nl80211: Could not set interface 'wlan0' UP
wlan0: Failed to initialize driver interface
For information I downloaded kernel 3.18 from the same site and merged with wilk1000 driver of different version 13.x 14.x but always get the message above. The board seems to work fine: mount USB pen drive and MMC/SD card without any problem, I also tried an old Zydas  Wifi pendrive and it works OK.
Thank you for your help!
Francesco
Solved! The problem was an erroneous activation of the Kernel configuration "Use out of band interrupt", on a standard SDIO slot it is'n connected!
Thanks!
Francesco
