Max ADC value from atmega32U4
5 posts / 0 new
The maximum ADC value that I can get from the atmega32u4 on a Yun is 1.25V. The voltage reference is AVCC and I am setting 1 << REFS0 in ADMUX. Thus I would expect the maximum to be 5V. Why is this discrepancy happening? Thanks.
#include <stdint.h>
#include <util/delay.h>
void init_adc()
    ADMUX = 1 << REFS0;
    ADCSRA = 1 << ADEN | 1 << ADPS2 | 1 << ADPS1 | 1 << ADPS0;
    ADCSRB = 0;
    ADCSRA |= 1 << ADSC;
    while( ADCSRA & 1 << ADSC)
uint8_t read_adc()
    return (255*ADCW/1023);
    init_adc();
    DDRD = 1 << DDD0;
    TCCR0A = 1 << COM0B1 | 1 << WGM00;
    TCCR0B = 1 << CS02 | 1 << CS00;
    while( 1)
        OCR0B = read_adc();
        _delay_ms(1000);
    return 0;
Start over -- the ADC value (on any ADC?) is never volts, but rather counts.
Report your counts until you get what you expect; THEN start worrying about units conversion.
And then you will find that your calculation as written overflows, giving you your symptom.
If ADCW is 1023 (the max value it may hold) then what do you think the result of this is?
(hint: "int" for AVR is 16 bit so has a numeric range of -32768..+32767).
See what happens if you add "UL" to the end of that 255.
Every app's needs and requirements are different.  That said, the shown test program uses the ADC results rather coarsely, as phase-correct PWM duty.  (Why phase-correct rather than fast?  Also, you might want to consider inverted PWM if normal gives you a one-count spike when the OC register is zero.)
Anyway, how far off are you going to be if you make your transfer function a simple /4?  Less than 0.1%...
Thanks both. That was very silly of me.
