How to Reading DS1307 RTC single address?
11 posts / 0 new
When i'm send Read DS1307 command through I2C,
DS1307 reply all data its have.(Time,Date,Data Register)
But i just want to know the time only.
whats the procedure thats give me only Time's data?
eRony
শূন্য  - The ZeRo
So you already have "read all" working?  Surely it is just a matter of specifying which register(s) you might want.
Show your driver code, and sample complete test program.
Why not just use the time data returned and throw away the rest?
eRony
Your answer can be found on page 12 of this DATASHEET.
Look in section: 2. Slave Transmitter Mode (Read Mode):
And look at figure 5.
If you use void functions,  you will get void answers.
It is a bit like driving a car blindfolded.    You might get to your destination.
Install a respected library.   Use the return values.    Get your program working.
Now that you have it working with round wheels,   you can start your square wheel development project.
All of your I2C functions are void.
You can solve your problem in 5 minutes by typing "AVR ds1307" into google and doing the slightest bit of research, or clicking on this LINK  where you can download a working library and follow the tutorial. The code you posted absolutely can not work. Sorry, I'm out.
