How to make a simple Hello World with Start.Atmel?
3 posts / 0 new
I just created a project with Start.Atmel and I would like to print some text on the USB serial port of my SAMD21 Xplained Pro board.
The generated code called system_init() which calls
    USART_0_init();
    USART_1_init();
    USART_2_init();
I just added a simple printf, but it doesn't work. I did include a STDIO_REDIRECT in my design, so I would have expected it to be working out of the box or to have some indications on how to do it.
#include "atmel_start.h"
#include "atmel_start_pins.h"
#include "stdio_start.h"
    system_init();
    printf("hello, world.\n");
    while(1) { }
I also checked some examples like the 8khz oscillator demo which do print things on the screen, but I couldn't mix it with my start.atmel code.
Could someone point me to some code on how to do this?
usually, Start creates example code that you can run from your main. Just search for _example or something similar in the solution and you should find some simple hello-world ish..
Looking at the project, in the file called stdio_start.c you have these two that you could call from main:
void STDIO_REDIRECT_0_init(void)
	usart_sync_enable(&USART_2);
	stdio_io_init(&USART_2.io);
void STDIO_REDIRECT_0_example(void)
	/* Print welcom message */
	printf("\r\nHello ATMEL World!\r\n");
:: Morten
Thank you Meolsen, it worked!
My previous attempts failed because I thought that the output will magically come from the USB port thanks to the STDIO__REDIRECT component.
But I needed to set the USART to pin PA22/PA23 and select the right baud rate, this is not the kind of thing you have to worry about on simpler MCU where TX/RX are on static pins
