Counter external signal SAM4S
2 posts / 0 new
Hi everybody,
I am trying to count the number of pulses of a signal which is connected to PA4 using TC0. The uC is the sam4sd32c. This is the code that I am using
#include "sam.h"
#include "asf.h"
    SystemInit();
        sysclk_enable_peripheral_clock(ID_PIOA);
        ioport_set_pin_mode(PIO_PA4B_TCLK0, IOPORT_MODE_MUX_B);
        ioport_disable_pin(PIO_PA4B_TCLK0);
        sysclk_enable_peripheral_clock(ID_TC0);
        tc_init(TC0, 0, TC_CMR_TCCLKS_XC1);
        tc_set_block_mode(TC0, TC_BMR_TC0XC0S_TCLK0);
        tc_start(TC0, 0);
        uint32_t count=0;
    while (1)
    count= tc_read_cv(TC0, 0);
It has no errors but I doesn't work. Could you help me, please?
Thank you
I see this question an year later, but I assume you got it working? May I ask how?
I'm trying something similar but using TIAO1 (PD15 input).
Best regards,
