Different/strange behaviour with or w/o ATMEL-ICE attached
5 posts / 0 new
I've a strange behaviour with an ATMEGA328P, ATMEL-ICE and my program, which I cannot resolve.
1) When building the solution (ATEMLSTUDIO7 on Win10), and programming the device using ATMEL-ICE, and then run the program, everything is fine. Even after toggling power on the device, everything is ok. (ATMELICE still attached)
2) When removing ATMEL-ICE (during operation and without toggling power on the device) -> everything is ok.
3) After removing ATMEL-ICE and toggling power, the program's not working as expected anymore.
In 3) there is the strange behaviour, that:
- timer are much faster (~factor 10 or so)
- some led's are in an undefined state (an are ON, but should not.)
I'm going to get another MCU short term to retest and see whether I "burned" the current MCU.
Any support to find out more about the reason would be great.
Regards
Andreas
Welcome to AVRFreaks.
A difference in expected times and or speed suggests a change in the clock speed by a factor of 8. Have you examined your fuse settings? One of them controls the divide by 8 parameter.
Cheers,
Ross
I checked the fuse settings, they're ok. Different parts of the program are ok, too (I've a "pause" mode that toggles an LED every 1s.)
What would be the difference with the ATMEL-ICE powered and plugged in to ISP (no dW)?
In my former tests I had the cable still attached, and was pretty surprised when running w/o ICE today.
Regards, Andreas
Are you sure?  Post a screenshot of your fuse settings.
What is the clock speed of your AVR?
Do you have a 10k resistor on the RESET line of the AVR tied to VCC?
JIm
Fuse settings are:
In my current development branch, I've an 8 MHz quartz and capacitors attached, deselected CKDIV8 is ok, too, and all timer are calculated using these values. (In the next version I'll go to 2 MHz, ext. resonator and set CKDIV8, too.)
Yes, a 10k resistor is tied, too.
In deed, I'd an issue in my code, which executed some single steps in the appropriate ISR every 1ms gone, but was expected to do only every 1s. Anyway, the code executed took only 15-20 steps, and thus should not be too long. The results are the same w/ and w/o ICE attached.
For me it's something like a lesson learnt to do early tests with the standalone device.
Although my issue is resolved now, I still don't have a clue why an attached ATMEL-ICE using ISP gives a different result than without the ISP attached. Any hint is very welcome.
Regards, Andreas
