naming port pins
8 posts / 0 new
WinAVR C compiler, ATmega16.
I'm trying to name a port pin, so I can use that name in the code.
ex:
PD2 is called SCK
PD3 is called DATA
void s_transstart(void)
// generates a transmission start
DATA=1; SCK=0; //Initial state
_nop_();
SCK=1;
_nop_();
DATA=0;
_nop_();
SCK=0;
_nop_();_nop_();_nop_();
SCK=1;
_nop_();
DATA=1;
_nop_();
SCK=0;
Probably something stupidly simple, but I don't have much experience with C or AVR yet. Thanks.
The definition of the bits is easy:
#define SCK PD2
#define DATA PD3
However, since these are just constant bit numbers and not variables, you can't use them directly, as in:
SCK = 0;
Instead you have to use something like:
PORTD |= (1 << SCK); //set SCK
PORTD &= ~(1 << SCK); //clear SCK
Steve A.
This always looks very ugly to me :(
#define SCK  (1 << PD2)
#define DATA (1 << PD3)
PORTD |=  SCK; //set   SCK
PORTD &= ~SCK; //clear SCK
Seems a much clearer expression of what you're actually trying to achieve... 8)
I agree, but it seems to be the standard around here.
Steve A.
The convention seems to be a carry-over from AVR assembly programming.
There are very good reasons why most special-purpose bits are defined according to their position rather than their mask in AVR assembly, because of the implementation of most bitwise op-codes.
C does not have such a restriction. However, heritage can be a strong source of inertia. As well, maintaining the same convention tends to allow a single set of common headers carry over from C to ASM programming and vice-versa. (This is particularly important, for example, in gcc, which really does use exactly the same headers for its assembler and its C compiler.)
Try:
#include
typedef struct {
  unsigned char bit0:1;
  unsigned char bit1:1;
  unsigned char bit2:1;
  unsigned char bit3:1;
  unsigned char bit4:1;
  unsigned char bit5:1;
  unsigned char bit6:1;
  unsigned char bit7:1;
}io_reg;
#define SCK   ((volatile io_reg*)_SFR_MEM_ADDR(PORTD))->bit2
#define DATA  ((volatile io_reg*)_SFR_MEM_ADDR(PORTD))->bit3
int
main(void)
 SCK = 0;
 SCK = 1;
This generates the code:
390:        SCK = 0;
+0000004B:   9892        CBI     0x12,2    Clear bit in I/O register
400:      	SCK = 1;
+0000004C:   9A92        SBI     0x12,2    Set bit in I/O register
(BTW, I'm not the originator of this technique but took a suggestion from someone else (who's name currently escapes me :( ) here on 'Freaks)
Cliff
That worked fine, now I have another problem.
I need to use DATA as both input and output. Other than changing DDRD, are there any other things I need to do?
ex:
//DDRD set for DATA as input
error=DATA;
The point is to set error to 1 if DATA is still high, 0 if it gets pulled low by external device. I used Clawson's method for naming the port.
I just assume its always set to IN... initialize it that way, and when you want to write to it, set it to out, write, then set it back to in
