Suart receive NEEDs help
10 posts / 0 new
Iam working on a 8 bits uP, AT328p in the Atmel studio, and try to make a software Uart receive for debugging staff. it doesnt work for me:(
I use the external interrupt INT0 as receive pin, and timer0 to count bit length. My problem is that (PIND&PIND2) is always getting high, i cant figure out why:(
Iam running at 16Mhz, prescaler 64, and using a external device send data at 9600N1.
Here is the code, pls spot the errors for me, thx in advanced.
int main( void )
	char c = 0;
	DDRD &= ~(1<<2);
	TCCR0A |= (1<<WGM01);
	TCCR0B = (1<<CS00)|(1<<CS01);
	EICRA |= (1<<ISC01);
	EIFR |= (1<<INTF0);
	EIMSK |= (1<<INT0);
	sei( );
	for( ; ; )
		c = SwUartRXData;
ISR(INT0_vect) {
	EIMSK &= ~(1<<INT0);			// Disable external interrupt
	TIMSK0 &= ~(1<<OCIE0A);
	TCNT0 = 0x00;
	OCR0A  = 39;  					// set timer reload value (to 1.5 bit length)
	SwUartRXBitCount = 0;
	TIFR0  |= (1<<OCF0A);		   	// clear timer compare flag
	TIMSK0 |= (1<<OCIE0A);		   		// enable timer compare interrupt
ISR(TIMER0_COMPA_vect)
	OCR0A = 26;
	//char c = 0;
		if( SwUartRXBitCount < 8 )
			SwUartRXBitCount++;
			SwUartRXData = (SwUartRXData>>1);   // Shift due to receiving LSB first.
			if(PIND & PIND2)
				SwUartRXData |= 0x80;           // If a logical 1 is read, let the data mirror this.
		TIMSK0 &= ~( 1<< OCIE0A );
		EIFR |= (1<<INTF0);
		EIMSK |= (1<<INT0);
Without more explicit information (compiler, libraries & etc) I am hesitant, but being an obnoxious fellow I will proceed anyway.
You are shifting in a '0' at every bit period, and then changing that to a '1' if PIND2 is 'true'.
PIND2, being defined, will always be true.
This is the XMEGA forum.  The ATmega328P is NOT an XMEGA.  You should have posted this in the megaAVR and tinyAVR forum.
Put your code in a code block.  It makes it much easier to read:
int main( void )
    char c = 0;
    DDRD &= ~(1<<2);
    EIFR |= (1<<INTF0);
    EIMSK |= (1<<INT0);
    sei( );
    for( ; ; )
        c = SwUartRXData;
ISR(INT0_vect) {
    TCNT0 = 0x00;
    OCR0A = 26;                            // one bit length
    //char c = 0;
            SwUartRXBitCount++;
            if(PIND2)
        EIFR |= (1<<INTF0);
        EIMSK |= (1<<INT0);
Greg Muth
Portland, OR, US
Make Xmega Great Again!
obs, pls remove the post, i will re-post in the right place.
Iam working on a 8 bits uP, AT328p, and try to make a software Uart receive for debugging staff. it doesnt work for me:(
I use the external interrupt INT0 as receive pin, and timer0 to count bit length. My problem is that PIND2 is always getting high, i cant figure out why:(
Iam running at 16Mhz, prescaler 8, and using a external device send data at 9600N1.
int main( void )
    char c = 0;
    DDRD &= ~(1<<2);
    EIFR |= (1<<INTF0);
    EIMSK |= (1<<INT0);
    sei( );
    for( ; ; )
        c = SwUartRXData;
ISR(INT0_vect) {
    TCNT0 = 0x00;
    //char c = 0;
            SwUartRXBitCount++;
            if(PIND2)
        EIFR |= (1<<INTF0);
        EIMSK |= (1<<INT0);
As pointed out in #2, PIND2 is a constant. You need to read the PIND register then mask for bit 2
If (PIND &(1<<PIND2))
Crikey it worked!!!
Anyway just to note that because it already had some replies I just merged the mis-placed thread in "Xmega" with this one. That does mean the question appears twice but "hey ho".
I did mask for bit 2, as you said (PIND&(1<<PIND2)), but it still read "high" all the time. :(
NOTE: I am sure the external device that sends data at 9600N1 is OK, I can receive it by the hardware UART. So it must be some errors in that code, pls help me out, kinda of getting headache from this :(
Did it work for U? REALLY?
What does your voltmeter, logic probe, logic analyser or oscilloscope have to say about that?
