UC3A3 max pin toggle frequency
5 posts / 0 new
Hi !
In order to familiarize myself with the UC3 micros, I setup an ASF-based application, see below.
Purpose: toggle a single I/O pin as fast as possible.
Hardware: UC3A3256 Xplained board, I/O pin PB03, aka GPIO35.
The board has a 12 MHz Crystal connected to XIN0 / XOUT0; CPU clock is set up to be 6 MHz.
The disassembly also looks as expected:
We have a load-store sequence in an endless loop. The reference Manual on the UC3 tells me that the ld.w, mov, st.w and rjmp instructions all take one "issue latency" which I suppose to mean one machine cycle. So, we have seven instructions for one square wave at the pin.
At fCPU = 6 MHz, one instruction takes 166,7 ns, therefore one square wave on PB03 should take 166,7 * 7 = 1166,7 ns.
At least, this is what I expected to see.
My logic analyzer shows me this:
which is exactly half of the expected pin toggle frequency. The small deviation from 2,33333.... µs is due to the fact that the analyzer samples at 100 MHz / 10 ns intervals.
I then re-read the GPIO datasheet section 20.5.1.5 to find this:
I am not sure what this means - any access to GPIO over the Peripheral Bus always takes 2 instruction cycles ?
Any guidance appreciated.
best,
Chris
Yes.  If you want to go faster you need to use the local bus:
Thanks Dan. That was it.
For future reference, here are the steps needed:
 - declare / initialize pointers to local bus addresses
 - enable local bus (CPUCR.LOCEN = 1)
 - issue set / clear / toggle instructions by deref'ing the local bus pointers
This way, there is actually one port access per CPU clock cycle.
BTW the project Name "led_toggle_interrupt"  is a remnant from another project. No Interrupts involved.
As can be seen, the pin toggle now only takes 166,7 ns - the same as one CPU instruction cycle.
Thank you c_bauer for posting the solution also. I have a doubt. Why you are measuring falling edge to rising edge in the second analyzer capture and not rising edge to rising edge (i.e one cycle) as before?
This was to emphasize the fact that there really _is_ one pin state change per CPU cycle.
So, using the local bus you can get down to half the CPU frequency, in this case it's fCPU = 6 MHz and the pin toggles at 3 MHz*.
If I'd use the peripheral bus for GPIOs it would be much less than that, as my first post says.
* This is is only true if you issue back-to-back read / write accesses, in a loop there is "rjmp" overhead.
And if you need the fastest possible square wave with duty cycle = 50 % I'd use one of the generic clocks.
They may output the undivided CPU frequency; very nice feature IMO.
Hope that helps.
Chris
