solved: AtmelStudio, Simulation and 2 Timer not in sync - problem
3 posts / 0 new
I'm going to debug a piece of code and I'm experiencining some difficulties. Unfortunately, I hadn't been able to find a solution in the forum yet.
Relevant piece of code:
// timer0 and timer1 are set to essentially the same configuration
volatile unsigned long counter_0a = 0;
volatile unsigned long counter_1a = 0;
// Interrupt for Timer/Counter0 Compare Match A
ISR ( TIMER0_COMPA_vect ) {
    counter_0a++;
// Interrupt for Timer/Counter1 Compare Match A
ISR ( TIMER1_COMPA_vect ) {
    counter_1a++;
// timer0
TCCR0B |= ((1 << WGM02) | (1 << CS02)); // Configure timer0 for CTC mode, start timer @F_CPU/256
OCR0A = 125;
TIMSK0 |= (1 << OCIE0A); // Enable Timer/Counter Compare Match A interrupt
// timer1
TCCR1B |= ((1 << WGM12) | (1 << CS12)); // Configure timer1 for CTC mode, start timer @F_CPU/256
OCR1A = 125;
TIMSK1 |= (1 << OCIE1A ); // Enable Timer/Counter Compare Match A interrupt
sei (); // Enable global interrupts
Since I have no HW availalbe yet, I'm using the Atmel Studio Simulation.
After running for some time, starting all from 0, I get the result:
counter_0a = 15;
counter_1a = 30;
I'd expect them both to be in sync?
Any suggestions?
Thanks in advance!
Regards Andreas
You haven't mentioned which AVR.  Let's assume ATmega48/88/168/328 family.
This:
... actually sets a non-existent timer mode:
Who knows what the simulator will do in such an instance.  However, as a guess, I'd say it would revert to mode 0, which would explain the roughly 1:2 ratio you are seeing, since the period for TIMER0 would be 256, not 126.
You are correctly setting CTC mode for TIMER1.
I'm using the atmega328p.
Yes, your're right. I somehow assumed the registers and configuration for timer0 and timer1 to be symmetrical, but WGM01 is located in TCR0A, and now the results are completely as expected. Thanks!
For completeness please find the corrected code:
    counter_0a++;
    counter_1a++;
// timer0
TCCR0A |= (1 << WGM01);     // Configure timer0 for CTC mode,
TCCR0B |= (1 << CS02);      // start timer @F_CPU/256
OCR0A = 125;
// timer1
OCR1A = 125;
Regards Andreas
