Hi guys. I've been trying to figure out I2C the past couple of days and I am stuck with a few bugs which I cannot rid myself of.
Short version: I have established an I2C link between the ATmega644P and a breakout board of the DS3231 RTC module, but when I request data I receive what appears to be nonsense.
Long version: Here is a schematic of what I have wired up (forgive my love for pen and paper, I'm slightly conservative):
The resonator runs at 16 MHz and I am using Atmel Studio 6.2 with the Atmel ICE debugger to program the AVR. I am using the TWI_master library from Atmel to do the protocol stuff which a friend of mine provided me with. I cannot say I fully understand the code, which is probably where my problem is. All the code can be found in the bottom of this post, and I hope my comments in main.c clarify what I'm thinking. The datasheet for the RTC module can be found here: http://datasheets.maximintegrated.com/en/ds/DS3231.pdf
The bytes I receive are put onto PORTD and I am using a virtual instrument called Level Reader with NI's myDAQ to read the output.
Symptoms:
- I do receive data, but when I am "sampling" every 2000 ms the 2nd byte of the buffer contains a random bit pattern, leading me to believe that the DS3231 does not set its register pointer correctly.
The first byte of the buffer, which should always be the address (0x68) of the module, is constantly equal to 0xD1.Correction: I forgot to bit-shift the 7 bit address and was therefore reading it incorrectly. The first byte of the received message is indeed the RTC's address 0x68.- I can read and write to the RTC module using an Arduino Uno and the Wire.h library without problems, so the problem is most likely software-related.
I do not have access to a logic analyzer at this time, so debugging is indeed a bit difficult. I hope I have provided you with enough information.
/***************************************************************************** * * Atmel Corporation * * File : TWI_Master.h * Compiler : IAR EWAAVR 2.28a/3.10c * Revision : $Revision: 1.13 $ * Date : $Date: 24. mai 2004 11:31:22 $ * Updated by : $Author: ltwa $ * * Support mail : avr@atmel.com * * Supported devices : All devices with a TWI module can be used. * The example is written for the ATmega16 * * AppNote : AVR315 - TWI Master Implementation * * Description : Header file for TWI_Master.c * Include this file in the application. * ****************************************************************************/ /**************************************************************************** TWI Status/Control register definitions ****************************************************************************/ #define TWI_BUFFER_SIZE 10 // Set this to the largest message size that will be sent including address byte. #define TWI_TWBR 0x0C // TWI Bit rate Register setting. // Se Application note for detailed // information on setting this value. // Gives 400 kHz SCL frq. // Not used defines! //#define TWI_TWPS 0x00 // This driver presumes prescaler = 00 /**************************************************************************** Global definitions ****************************************************************************/ union TWI_statusReg // Status byte holding flags. { unsigned char all; struct { unsigned char lastTransOK:1; unsigned char unusedBits:7; }; }; extern union TWI_statusReg TWI_statusReg; /**************************************************************************** Function definitions ****************************************************************************/ void TWI_Master_Initialise( void ); unsigned char TWI_Transceiver_Busy( void ); unsigned char TWI_Get_State_Info( void ); void TWI_Start_Transceiver_With_Data( unsigned char * , unsigned char ); void TWI_Start_Transceiver( void ); unsigned char TWI_Get_Data_From_Transceiver( unsigned char *, unsigned char ); /**************************************************************************** Bit and byte definitions ****************************************************************************/ #define TWI_READ_BIT 0 // Bit position for R/W bit in "address byte". #define TWI_ADR_BITS 1 // Bit position for LSB of the slave address bits in the init byte. #define TRUE 1 #define FALSE 0 /**************************************************************************** TWI State codes ****************************************************************************/ // General TWI Master staus codes #define TWI_START 0x08 // START has been transmitted #define TWI_REP_START 0x10 // Repeated START has been transmitted #define TWI_ARB_LOST 0x38 // Arbitration lost // TWI Master Transmitter staus codes #define TWI_MTX_ADR_ACK 0x18 // SLA+W has been tramsmitted and ACK received #define TWI_MTX_ADR_NACK 0x20 // SLA+W has been tramsmitted and NACK received #define TWI_MTX_DATA_ACK 0x28 // Data byte has been tramsmitted and ACK received #define TWI_MTX_DATA_NACK 0x30 // Data byte has been tramsmitted and NACK received // TWI Master Receiver staus codes #define TWI_MRX_ADR_ACK 0x40 // SLA+R has been tramsmitted and ACK received #define TWI_MRX_ADR_NACK 0x48 // SLA+R has been tramsmitted and NACK received #define TWI_MRX_DATA_ACK 0x50 // Data byte has been received and ACK tramsmitted #define TWI_MRX_DATA_NACK 0x58 // Data byte has been received and NACK tramsmitted // TWI Slave Transmitter staus codes #define TWI_STX_ADR_ACK 0xA8 // Own SLA+R has been received; ACK has been returned #define TWI_STX_ADR_ACK_M_ARB_LOST 0xB0 // Arbitration lost in SLA+R/W as Master; own SLA+R has been received; ACK has been returned #define TWI_STX_DATA_ACK 0xB8 // Data byte in TWDR has been transmitted; ACK has been received #define TWI_STX_DATA_NACK 0xC0 // Data byte in TWDR has been transmitted; NOT ACK has been received #define TWI_STX_DATA_ACK_LAST_BYTE 0xC8 // Last data byte in TWDR has been transmitted (TWEA = “0”); ACK has been received // TWI Slave Receiver staus codes #define TWI_SRX_ADR_ACK 0x60 // Own SLA+W has been received ACK has been returned #define TWI_SRX_ADR_ACK_M_ARB_LOST 0x68 // Arbitration lost in SLA+R/W as Master; own SLA+W has been received; ACK has been returned #define TWI_SRX_GEN_ACK 0x70 // General call address has been received; ACK has been returned #define TWI_SRX_GEN_ACK_M_ARB_LOST 0x78 // Arbitration lost in SLA+R/W as Master; General call address has been received; ACK has been returned #define TWI_SRX_ADR_DATA_ACK 0x80 // Previously addressed with own SLA+W; data has been received; ACK has been returned #define TWI_SRX_ADR_DATA_NACK 0x88 // Previously addressed with own SLA+W; data has been received; NOT ACK has been returned #define TWI_SRX_GEN_DATA_ACK 0x90 // Previously addressed with general call; data has been received; ACK has been returned #define TWI_SRX_GEN_DATA_NACK 0x98 // Previously addressed with general call; data has been received; NOT ACK has been returned #define TWI_SRX_STOP_RESTART 0xA0 // A STOP condition or repeated START condition has been received while still addressed as Slave // TWI Miscellaneous status codes #define TWI_NO_STATE 0xF8 // No relevant state information available; TWINT = “0” #define TWI_BUS_ERROR 0x00 // Bus error due to an illegal START or STOP condition
/***************************************************************************** * * Atmel Corporation * * File : TWI_Master.c * Compiler : IAR EWAAVR 2.28a/3.10c * Revision : $Revision: 1.13 $ * Date : $Date: 24. mai 2004 11:31:20 $ * Updated by : $Author: ltwa $ * * Support mail : avr@atmel.com * * Supported devices : All devices with a TWI module can be used. * The example is written for the ATmega16 * * AppNote : AVR315 - TWI Master Implementation * * Description : This is a sample driver for the TWI hardware modules. * It is interrupt driveren. All functionality is controlled through * passing information to and from functions. Se main.c for samples * of how to use the driver. * * ****************************************************************************/ #include <avr/io.h> #include <avr/interrupt.h> #include "TWI_Master.h" static unsigned char TWI_buf[ TWI_BUFFER_SIZE ]; // Transceiver buffer static unsigned char TWI_msgSize; // Number of bytes to be transmitted. static unsigned char TWI_state = TWI_NO_STATE; // State byte. Default set to TWI_NO_STATE. union TWI_statusReg TWI_statusReg = {0}; // TWI_statusReg is defined in TWI_Master.h /**************************************************************************** Call this function to set up the TWI master to its initial standby state. Remember to enable interrupts from the main application after initializing the TWI. ****************************************************************************/ void TWI_Master_Initialise(void) { TWBR = TWI_TWBR; // Set bit rate register (Baudrate). Defined in header file. // TWSR = TWI_TWPS; // Not used. Driver presumes prescaler to be 00. TWDR = 0xFF; // Default content = SDA released. TWCR = (1<<TWEN)| // Enable TWI-interface and release TWI pins. (0<<TWIE)|(0<<TWINT)| // Disable Interupt. (0<<TWEA)|(0<<TWSTA)|(0<<TWSTO)| // No Signal requests. (0<<TWWC); } /**************************************************************************** Call this function to test if the TWI_ISR is busy transmitting. ****************************************************************************/ unsigned char TWI_Transceiver_Busy( void ) { return ( TWCR & (1<<TWIE) ); // IF TWI Interrupt is enabled then the Transceiver is busy } /**************************************************************************** Call this function to fetch the state information of the previous operation. The function will hold execution (loop) until the TWI_ISR has completed with the previous operation. If there was an error, then the function will return the TWI State code. ****************************************************************************/ unsigned char TWI_Get_State_Info( void ) { while ( TWI_Transceiver_Busy() ); // Wait until TWI has completed the transmission. return ( TWI_state ); // Return error state. } /**************************************************************************** Call this function to send a prepared message. The first byte must contain the slave address and the read/write bit. Consecutive bytes contain the data to be sent, or empty locations for data to be read from the slave. Also include how many bytes that should be sent/read including the address byte. The function will hold execution (loop) until the TWI_ISR has completed with the previous operation, then initialize the next operation and return. ****************************************************************************/ void TWI_Start_Transceiver_With_Data( unsigned char *msg, unsigned char msgSize ) { unsigned char temp; while ( TWI_Transceiver_Busy() ); // Wait until TWI is ready for next transmission. TWI_msgSize = msgSize; // Number of data to transmit. TWI_buf[0] = msg[0]; // Store slave address with R/W setting. if (!( msg[0] & (TRUE<<TWI_READ_BIT) )) // If it is a write operation, then also copy data. { for ( temp = 1; temp < msgSize; temp++ ) TWI_buf[ temp ] = msg[ temp ]; } TWI_statusReg.all = 0; TWI_state = TWI_NO_STATE ; TWCR = (1<<TWEN)| // TWI Interface enabled. (1<<TWIE)|(1<<TWINT)| // Enable TWI Interupt and clear the flag. (0<<TWEA)|(1<<TWSTA)|(0<<TWSTO)| // Initiate a START condition. (0<<TWWC); // } /**************************************************************************** Call this function to resend the last message. The driver will reuse the data previously put in the transceiver buffers. The function will hold execution (loop) until the TWI_ISR has completed with the previous operation, then initialize the next operation and return. ****************************************************************************/ void TWI_Start_Transceiver( void ) { while ( TWI_Transceiver_Busy() ); // Wait until TWI is ready for next transmission. TWI_statusReg.all = 0; TWI_state = TWI_NO_STATE ; TWCR = (1<<TWEN)| // TWI Interface enabled. (1<<TWIE)|(1<<TWINT)| // Enable TWI Interupt and clear the flag. (0<<TWEA)|(1<<TWSTA)|(0<<TWSTO)| // Initiate a START condition. (0<<TWWC); // } /**************************************************************************** Call this function to read out the requested data from the TWI transceiver buffer. I.e. first call TWI_Start_Transceiver to send a request for data to the slave. Then Run this function to collect the data when they have arrived. Include a pointer to where to place the data and the number of bytes requested (including the address field) in the function call. The function will hold execution (loop) until the TWI_ISR has completed with the previous operation, before reading out the data and returning. If there was an error in the previous transmission the function will return the TWI error code. ****************************************************************************/ unsigned char TWI_Get_Data_From_Transceiver( unsigned char *msg, unsigned char msgSize ) { unsigned char i; while ( TWI_Transceiver_Busy() ); // Wait until TWI is ready for next transmission. if( TWI_statusReg.lastTransOK ) // Last transmission competed successfully. { for ( i=0; i<msgSize; i++ ) // Copy data from Transceiver buffer. { msg[ i ] = TWI_buf[ i ]; } } return( TWI_statusReg.lastTransOK ); } // ********** Interrupt Handlers ********** // /**************************************************************************** This function is the Interrupt Service Routine (ISR), and called when the TWI interrupt is triggered; that is whenever a TWI event has occurred. This function should not be called directly from the main application. ****************************************************************************/ //#pragma vector=TWI_vect //__interrupt void TWI_ISR(void) ISR(TWI_vect) { static unsigned char TWI_bufPtr; switch (TWSR) { case TWI_START: // START has been transmitted case TWI_REP_START: // Repeated START has been transmitted TWI_bufPtr = 0; // Set buffer pointer to the TWI Address location case TWI_MTX_ADR_ACK: // SLA+W has been tramsmitted and ACK received case TWI_MTX_DATA_ACK: // Data byte has been tramsmitted and ACK received if (TWI_bufPtr < TWI_msgSize) { TWDR = TWI_buf[TWI_bufPtr++]; TWCR = (1<<TWEN)| // TWI Interface enabled (1<<TWIE)|(1<<TWINT)| // Enable TWI Interupt and clear the flag to send byte (0<<TWEA)|(0<<TWSTA)|(0<<TWSTO)| // (0<<TWWC); // }else // Send STOP after last byte { TWI_statusReg.lastTransOK = TRUE; // Set status bits to completed successfully. TWCR = (1<<TWEN)| // TWI Interface enabled (0<<TWIE)|(1<<TWINT)| // Disable TWI Interrupt and clear the flag (0<<TWEA)|(0<<TWSTA)|(1<<TWSTO)| // Initiate a STOP condition. (0<<TWWC); // } break; case TWI_MRX_DATA_ACK: // Data byte has been received and ACK tramsmitted TWI_buf[TWI_bufPtr++] = TWDR; case TWI_MRX_ADR_ACK: // SLA+R has been tramsmitted and ACK received if (TWI_bufPtr < (TWI_msgSize-1) ) // Detect the last byte to NACK it. { TWCR = (1<<TWEN)| // TWI Interface enabled (1<<TWIE)|(1<<TWINT)| // Enable TWI Interupt and clear the flag to read next byte (1<<TWEA)|(0<<TWSTA)|(0<<TWSTO)| // Send ACK after reception (0<<TWWC); // }else // Send NACK after next reception { TWCR = (1<<TWEN)| // TWI Interface enabled (1<<TWIE)|(1<<TWINT)| // Enable TWI Interupt and clear the flag to read next byte (0<<TWEA)|(0<<TWSTA)|(0<<TWSTO)| // Send NACK after reception (0<<TWWC); // } break; case TWI_MRX_DATA_NACK: // Data byte has been received and NACK tramsmitted TWI_buf[TWI_bufPtr] = TWDR; TWI_statusReg.lastTransOK = TRUE; // Set status bits to completed successfully. TWCR = (1<<TWEN)| // TWI Interface enabled (0<<TWIE)|(1<<TWINT)| // Disable TWI Interrupt and clear the flag (0<<TWEA)|(0<<TWSTA)|(1<<TWSTO)| // Initiate a STOP condition. (0<<TWWC); // break; case TWI_ARB_LOST: // Arbitration lost TWCR = (1<<TWEN)| // TWI Interface enabled (1<<TWIE)|(1<<TWINT)| // Enable TWI Interupt and clear the flag (0<<TWEA)|(1<<TWSTA)|(0<<TWSTO)| // Initiate a (RE)START condition. (0<<TWWC); // break; case TWI_MTX_ADR_NACK: // SLA+W has been tramsmitted and NACK received case TWI_MRX_ADR_NACK: // SLA+R has been tramsmitted and NACK received case TWI_MTX_DATA_NACK: // Data byte has been tramsmitted and NACK received // case TWI_NO_STATE // No relevant state information available; TWINT = 0 case TWI_BUS_ERROR: // Bus error due to an illegal START or STOP condition default: TWI_state = TWSR; // Store TWSR and automatically sets clears noErrors bit. // Reset TWI Interface TWCR = (1<<TWEN)| // Enable TWI-interface and release TWI pins (0<<TWIE)|(0<<TWINT)| // Disable Interupt (0<<TWEA)|(0<<TWSTA)|(0<<TWSTO)| // No Signal requests (0<<TWWC); // } }
/***************************************************************************** * * main.c, constructed using examples found in the main file provided by Atmel * ****************************************************************************/ #define F_CPU 16000000 #include <avr/io.h> #include <avr/interrupt.h> #include <util/delay.h> #include "TWI_Master.h" #define TWI_GEN_CALL 0x00 // The General Call address is 0 // Sample TWI transmission commands #define TWI_CMD_MASTER_WRITE 0x10 #define TWI_CMD_MASTER_READ 0x20 // Sample TWI transmission states, used in the main application. #define SEND_DATA 0x01 #define REQUEST_DATA 0x02 #define READ_DATA_FROM_BUFFER 0x03 #define DS3231 0x68 // address of RTC unsigned char bcdToDec(unsigned char val){ return((val / 16 * 10) + (val % 16)); } unsigned char decToBcd(unsigned char val){ return((val / 10 * 16) + (val % 10)); } void readTime(unsigned char* buffer, unsigned char bufferSize){ unsigned char messageBuf[2]; // send request for 2 bytes messageBuf[0] = (DS3231 << TWI_ADR_BITS) | (TRUE << TWI_READ_BIT); // first byte: slave adr. and r/w bit. messageBuf[1] = 0; // second byte: pointer to address TWI_Start_Transceiver_With_Data(messageBuf, 2); // send command to DS3231 TWI_Get_Data_From_Transceiver(buffer, bufferSize); // collect data, request 4 bytes [addr], s, m, h } int main( void ){ DDRD = 0xff; //feedback/debug port PORTD = 0x0; TWI_Master_Initialise(); // initialize i2c sei(); // enable all interrupts unsigned char readBuf[4]{}; // contains [addr], seconds, minutes, hour while(1){ readTime(readBuf, 4); // reads time from DS3231 into buffer PORTD = bcdToDec(readBuf[1] & 0x7f); // output data to Digital Reader // masking out MSB bit and converting to decimal _delay_ms(2000); } }
There is probably a better way to include code, but am unfamiliar with this editor.
