confusion about flash-strings
3 posts / 0 new
I am a little bit confused at the moment regarding flash-strings on UC3.
Has anyone an idea why this doesn't compile?
typedef struct {
	uint8_t cp;
	uint8_t font;
	uint8_t align;
	const void *str;
}flash_string_meta_t;
const char str_en_0[] = "apple";
const char str_en_1[] = "banana";
const char str_en_2[] = "peach";
const char* test_strings_en[] = {
	str_en_0,
	str_en_1,
	str_en_2
const flash_string_meta_t test_strings_meta_en[] = {
	{ .cp = 1,	.font = 0,	.align = 0,	.str = test_strings_en[0] },
	{ .cp = 1,	.font = 0,	.align = 0,	.str = test_strings_en[1] },
	{ .cp = 1,	.font = 0,	.align = 0,	.str = test_strings_en[2] }
glcd_print_string((char *)test_strings_meta_en[0].str, 0, 55, &font5x8, 0, 0);
     Compiler output:
Error    171    initializer element is not constant    ...
     (which refers to test_strings_meta_de[0])
The equivalent approach for 8-bit AVRs is like this:
http://www.atmel.com/webdoc/AVRLibcReferenceManual/FAQ_1faq_rom_array.html
I assume you mean it refers to test_strings_meta_en[0]?  There's no definition for a ..._de[0].
Anyway, "test_strings_en" is not a constant according to the C standard.  It doesn't matter that you have your variable defined as const, it's still a variable as far as initialization is concerned.
this works for me now :)
(note the pointer-pointer on "str")
typedef struct {
	uint8_t cp;
	uint8_t font;
	uint8_t fmt;
	void **str;
	{ .cp = 0,	.font = 0,	.fmt = 0,	.str = &((char *){"voltage"}) },
	{ .cp = 0,	.font = 0,	.fmt = 0,	.str = &((char *){"current"}) },
	{ .cp = 0,	.font = 0,	.fmt = 0,	.str = &((char *){"temperature"}) }
glcd_print_string((char *)*test_strings_meta_en[0].str, 0, 55, &font5x8, 0, 0);
which gives me the possibility to do this:
const flash_string_meta_t test_strings_meta_cn[] = {
	{ .cp = 1,	.font = 1,	.fmt = 0,	.str = &((wchar_t *){L"电压"}) },
	{ .cp = 1,	.font = 1,	.fmt = 0,	.str = &((wchar_t *){L"当前"}) },
	{ .cp = 1,	.font = 1,	.fmt = 0,	.str = &((wchar_t *){L"温度"}) }
glcd_print_wstring((wchar_t *)*test_strings_meta_cn[0].str, 0, 55, &font16_prop, 0, 0);
