Pasting Macros
11 posts / 0 new
I've messed with this for more time than I care to admit and am still unable to get the desired result.  What I would like to do is define a macro that contains the name of a USART and define macros that will expand to the various interrupt vector names.
// I want to do something like this
#define MY_USART        USARTC0
#define DRE_VECT(u)     u##_DRE_vect
#define RXC_VECT(u)     u##_RXC_vect
#define TXC_VECT(u)     u##_TXC_vect
// so I can do this:
ISR(DRE_VECT(MY_USART))
    // ISR code
// and have it expand to this:
ISR(USARTC0_DRE_vect)
    // ISR code
// I've tried using the ASF token paste macro:
#define TPASTE2(a, b)   a##b
// and absolute token paste macro:
#define ATPASTE2(a, b)  TPASTE2(a, b)
What am I missing?
Greg Muth
Portland, OR, US
Make Xmega Great Again!
You define the concatenation macros but then never use them, why?
I have used the *PASTE2 macros in every combination I can think of and have still not got the desired result.  I'm just not getting it.  HELP!
Greg Muth
Portland, OR, US
https://gcc.gnu.org/onlinedocs/cpp/Concatenation.html
#include <avr/interrupt.h>
#define CONCATENATE(a, b) CONCATENATE_(a, b)
#define CONCATENATE_(a, b) a ## b
#define DRE_VECT(u)     CONCATENATE(u, _DRE_vect)
#define RXC_VECT(u)     CONCATENATE(u, _RXC_vect)
#define TXC_VECT(u)     CONCATENATE(u, _TXC_vect)
    // ISR code
I was helped here with exactly the same situation--making "generic" RS485 USART drivers, applicable to different USART instances and pin configurations (and buffer sizes). See the link below for full macro setup:
https://www.avrfreaks.net/comment...
david.prentice provided the MKPORT() which I adapted:
https://www.avrfreaks.net/forum/g...
An example of a macroed-up ISR in CodeVision-speak:
// UART Transmitter interrupt service routine
interrupt [VECT_TXC] void 	uart_tx_isr			(void)
if (tx_ctr)
   RS485_TE();	// ensure that the MAX485 is transmit-enabled
   --tx_ctr;
   URD = tx_buffer[tx_rd_index];
   if (++tx_rd_index >= TX_BUFFER_SIZE) tx_rd_index=0;
	//  Use MPCM to wait for our address
	URA |= MPCM_MODE;
	RS485_RE();	// switch the MAX485 to receive mode
When I do this:
92  #define MY_USART			USARTD0
93  #define CONCATENATE_(a, b)	a ## b
94  #define CONCATENATE(a, b)	CONCATENATE_(a, b)
95  #define DRE_VECT(u)			CONCATENATE(u, _DRE_vect)
96  #define RXC_VECT(u)			CONCATENATE(u, _RXC_vect)
97  #define TXC_VECT(u)			CONCATENATE(u, _TXC_vect)
98
99 ISR(DRE_VECT(MY_USART))
100 //ISR(USARTD0_DRE_vect)
101 {
The result is this:
Severity    Code    Description    Project    File    Line
Message        in expansion of macro 'MY_USART'    XE5X non-ASF    C:\Users\Greg\Documents\Atmel Studio\7.0\XE5X non-ASF\XE5X non-ASF\src\cons.c    100
Error        pasting ")" and "_DRE_vect" does not give a valid preprocessing token    XE5X non-ASF    C:\Users\Greg\Documents\Atmel Studio\7.0\XE5X non-ASF\XE5X non-ASF\src\cons.c    92
Error        expected ')' before '*' token    XE5X non-ASF    C:\Users\Greg\Documents\Atmel Studio\7.0\XE5X non-ASF\XE5X non-ASF\src\cons.c    92
Error        expected ')' before numeric constant    XE5X non-ASF    C:\Users\Greg\Documents\Atmel Studio\7.0\XE5X non-ASF\XE5X non-ASF\src\cons.c    92
Message        in definition of macro 'CONCATENATE_'    XE5X non-ASF    C:\Users\Greg\Documents\Atmel Studio\7.0\XE5X non-ASF\XE5X non-ASF\src\cons.c    93
Message        in expansion of macro 'CONCATENATE_'    XE5X non-ASF    C:\Users\Greg\Documents\Atmel Studio\7.0\XE5X non-ASF\XE5X non-ASF\src\cons.c    94
Message        in expansion of macro 'CONCATENATE'    XE5X non-ASF    C:\Users\Greg\Documents\Atmel Studio\7.0\XE5X non-ASF\XE5X non-ASF\src\cons.c    95
Message        in expansion of macro 'DRE_VECT'    XE5X non-ASF    C:\Users\Greg\Documents\Atmel Studio\7.0\XE5X non-ASF\XE5X non-ASF\src\cons.c    100
Greg Muth
Portland, OR, US
DOH!!!
This explains a lot (from iox32e5.h):
#define USARTD0 (*(USART_t *) 0x09C0)
This works as desired:
#define CONCAT2_(a, b)		a ## b
#define CONCAT2(a, b)		CONCAT2_(a, b)
#define CONCAT3_(a, b, c)	a ## b ## c
#define CONCAT3(a, b, c)	CONCAT3_(a, b, c)
#define CONS_USART		D0
#define USART(u)		CONCAT2(USART, u)
#define DRE_VECT(u)		CONCAT3(USART, u, _DRE_vect)
#define RXC_VECT(u)		CONCAT3(USART, u, _RXC_vect)
#define TXC_VECT(u)		CONCAT3(USART, u, _TXC_vect)
ISR(RXC_VECT(CONS_USART))
    char c = USART(CONS_USART).DATA;
Thanks for the help everyone!
blush
Greg Muth
Portland, OR, US
I hadn't recognised that you were working with Xmega, and that USARTC0 was a macro already defined by the device header.  The example I gave will work only if MY_USART is defined as something which does not itself expand, such as USART0 or USART1 in, for example, an ATmega2560.
I didn't realize USARTC0 was a macro either, although the UPPERCASE name should have tipped me off.  As it turns out, that was the source of my problems.
Thanks for your help!
Greg Muth
Portland, OR, US
My point was that in the mega/tiny families there is no such macro.  For example, the m1284p has two USARTs, >>referred<< to as USART0 and USART1, but there are no macros by those names.  The only macros which include those characters are the names of the interrupt vectors:
USART0_RX_vect
USART0_UDRE_vect
USART0_TX_vect
USART1_RX_vect
USART1_UDRE_vect
USART1_TX_vect
Your use of a macro called MY_USART and defined as USART0 or USART1 would work because there would be no further to expand.  In the case of the Xmega, those are actual macros, defined as structs living at the perpheral's base I/O address.  Since the concatenation macros are constructed such that the arguments are fully expanded before concatenation, this would fail.  Your solution seems a reasonable compromise.
Greg_Muth, you might be interested by HWA.
HWA : hardware abstraction for micro controllers, in pure standard C, without penalties.
