How to convert Float To String?
7 posts / 0 new
I'm using Atmel Studio 6.2.
One of my project i'm need to Convert a Float value to String.
Searching on google but Failed to find useful something.
Dose WinAvr Compiler have any Lib like (atoi) to convert Float to String?
eRony
শূন্য  - The ZeRo
Check this out:
http://www.geeksforgeeks.org/con...
Also look up SPRINTF
http://www.tutorialspoint.com/c_...
dtostrf()
Use <stdlib.h>
Make sure the build links with libm.a
(the above for GCC)
Alternatively every C compiler on planet earth surely knows about sprintf("%f") ?
Dear sir,
i know the sprintf();
but you know that i'm coding for MCU.
itz not PC.
and you can use the suggested commands for the MCU
JIm
itz not PC.
So?
How about you start with the documentation?
http://www.nongnu.org/avr-libc/user-manual/group__avr__stdio.html
http://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html
You are the one that said "float". No one coding for MCUs normally goes anywhere near float. If you do it costs an instant 1K. If you then want to print (ie convert to ASCII) them that "costs" a further 2K.
As I say dtostrf() is a "lightweight" way to get a float converted to ASCII characters.
Here is an example. It's completely fictious and doesn't make a lot of sense but kind of shows the "costs" involved:
$ cat avr.c
int main(void) {
  float f;
  f = 3.14 * PINB;
  PORTC = f;
  while(1);
$ avr-gcc -Os -mmcu=atmega16 avr.c -o avr.elf -lm
$ avr-size avr.elf
   text	   data	    bss	    dec	    hex	filename
    718	      0	      0	    718	    2ce	avr.elf
So just including a floating point multiply cost about 600..700 bytes. If I then use dtostrf() I get:
$ cat avr.c
#include <stdlib.h>
char buffer[20];
int main(void) {
  float f;
  f = 3.14 * PINB;
  dtostrf(f, 6, 4, buffer);
  PORTC = buffer[0];
  while(1);
$ avr-size avr.elf
   2208	      0	     20	   2228	    8b4	avr.elf
So the float->ASCII stuff has "cost" an additional 1,500 bytes. If I go with sprintf() then it is:
$ cat avr.c
#include <stdlib.h>
#include <stdio.h>
char buffer[20];
int main(void) {
  float f;
  f = 3.14 * PINB;
  sprintf(buffer, "%f", f);
  PORTC = buffer[0];
  while(1);
$ avr-gcc -Os -mmcu=atmega16 -Wl,-u,vfprintf avr.c -o avr.elf -lm -lprintf_flt
$ avr-size avr.elf
   3736	      4	     20	   3760	    eb0	avr.elf
On the other hand you only pay the sprintf() cost once and it is a far more utilitarian function. But if space is tight and you insist on using "float" in an MCU then stick to dtostrf() and pay the 1,500 byte cost.
