another strange error in Mega128's datasheet
5 posts / 0 new
I use Timer1 in Fast PWM mode 15, and COM1C1:0 = 2 and I found that the actually output waveform was the opposite, so Figure 52 is fucking wrong then!!!!
How could ATMEL got such a big mistake on their datasheet????
The datasheet looks ok to me. Here is a small test for mode 15 which does produce the expected 1/3 duty cycle on OC1C. As I understand your problem report it would output a 2/3 duty cycle. Can you show the code that is not working as expected?
#include
    DDRB = (1<<7); // OC1C output
    // Mode 15
    TCCR1A = (1<<WGM11)|(1<<WGM10);
    TCCR1B = (1<<WGM13)|(1<<WGM12);
    // Set TOP for ~100Hz
    OCR1A = (F_CPU/256/100);
    // OC1C clear on compare, set at TOP
    TCCR1A |= (1<<COM1C1);
    // OC1C 1/3 duty cycle
    OCR1C = OCR1A/3;
    TCCR1B |= (1<<CS12);     // Start with /256 prescaler
/Lars
use Timer1 in Fast PWM mode 15, and COM1C1:0 = 2 and I found [...]
Running on the actual chip or in the AVR Studio simulator? The latter has serious bugs for a lot of timer modes.
hehe, sorry, guys, it's my old analyzer's software problem, so it's correct
An apology to Atmel would be more in order I feel!
And please a more temperate use of words
Keep it simple it will not bite as hard
