[MODERATORS NOTE: BINARY ONLY RELEASES NOT ALLOWED. BINARIES REMOVED, THREAD LOCKED]
Turn Your Butterfly into a [SUPERFLY] Speed Demon by adding a 4-Speed Transmission and a Super Charger!
Due to Lock-Up problem with Butterfly Booter you should replace original BootLoader. Replace it with [SUPERFLY] or [SUPERFLEA].
MAIN FEATURES:
a) SMALLER: Only 240 (or 378) words (original is 1500+)
b) SECURE - Can't accidentally alter fuse/lockbits - No LOCKOUTS
c) SAFER - Extra Warning - No Accidental Over-Writes
d) FASTER - Joystick Up Launch programs at Turbo (High) Speed
e) FLEXABLE - Joystick Down at Original (2MHz) Speed
f) ADDITIONAL- Joystick Left goes Mid-Speed (4Mhz)
g) VARIETY- Joystick Right is Slow Speed (1Mhz)
h) FASTER - Programs Upload Quicker
i) EFFICIENT - Conserves Battery with "Sleep Mode"
j) EASIER Stack set-up, no need to do it in your program.
i) ROOMIER - More program space for your Applications
k) CONVIENIENT - Don't waste code on speed selection
l) SIMPLE - Works like original, no extra docs needed
(FREE for personal or educational, non-commercial applications. All rights reserved.)
CURRENT UPDATES 2006: .
MAR-16 Size reduction [SUPERFLEA] from 254 to 240
MAR-18 [SUPERFLY] v0.9d "Quad Speed" 1/2/4/8 MHz
MAR-19 [SUPERFLEA] "Quad Speed" v0.9d edition.
I can't get Lock-Up or Failure from either of these and no has reported a single one to date. If you do, let us know ASAP.
Thank to the AVRfreaks that helped me with this project especially Giorgos K.
