Studio 7 - device programmers
11 posts / 0 new
Windows 10
New install of Studio - thought I would see if it fixed a few issues.  Not sure it fixed any yet, but know it has caused a few.
Does not see AVR ISP MKII programmer.  Already a thread on that one.
JTAGICE 3 - needs to upgrade the firmware.  - problem, can not upgrade the firmware.  So the tool can see it, you just can't use it.
  Details:
 firmware version on tool  3.25.  On Disk 3.2a   (not sure "a" comes after 5 but these firmware developers are usually smarter than me)
While trying to upgrade get the message
firmware upgrade failed, toggle power on tool and retry upgrade
Try to do a fw upgrade from the command line. See here (exchange 6.2 for 7.0).
If it still fails, add '-v 8' to the command line to turn up the log level and attach it here...
:: Morten
C:\Program Files (x86)\Atmel\Studio\7.0\atbackend>atfw -t jtagice3 -a "c:\Program Files (x86)\Atmel\Studio\7.0\tools\JTAGICE3\jtagice3_fw.zip" -v 8
23:32:25: [init] Initializing logging subsystem
23:32:25: [init] Logging to file: C:\Users\edross\AppData\Local\Temp\atfw.9946-5a28-d5ef-dbd4.log
23:32:25: [init] Finished initializing logging subsystem
23:32:25: [cli] Starting execute stage
23:32:25: [cli] Enumerating connected tools and serial numbers:
23:32:25: [usb] WDU_INIT failed: No valid license (0x20000009).
23:32:27: [cli] No serial number given
23:32:27: [cli] No tool found based on serial
23:32:27: [cli] No Tool is found
The log file contains the same data as the console output
You are seeing the same Jungo on Windows 10 issue as reported in the Atmel Studio forum. Check those threads out...
:: Morten
Someone suggested on one of the other threads that a windows 10 reset would fix all problems.  Out of desperation I tried it.  Seemed to fix all problems.
Able to upgrade my avr jtagice3 to the latest release  (by the way, going from 3.5 to 3.a does not seem like it is an upgrade.  are the numbers in hex?)
Also, able to see and use my avrisp MKII programmer.
I wish I had noticed the driver version before the reset - but the Jungo version after the upgrade is 11.1.0.0 dated 1/5/2013
This was/is painful.  hope I don't have to do that again.
I'm getting a different log when trying command line upgrade but still doesn't work:
17:04:43: [init] Initializing logging subsystem
17:04:43: [init] Logging to file: C:\Users\grgsa\AppData\Local\Temp\atfw.c06b-5883-27d8-8be6.log
17:04:44: [init] Finished initializing logging subsystem
17:04:44: [cli] Starting execute stage
17:04:44: [cli] Enumerating connected tools and serial numbers:
17:04:44: [usb] WDU_INIT failed: No valid license (0x20000009).
17:04:44: [cli] J30200026855
17:04:46: [cli] No serial number given
17:04:46: [cli] Choosing first serial
17:04:46: [cli] Found
17:04:46: [cli] jtagice3
17:04:46: [cli] :
17:04:46: [cli] J30200026855
17:04:46: [cli] Creating upgrader for jtagice3(J30200026855)
17:04:46: [cli] Have upgrader, continue
17:04:46: [cli] Start reading firmware from archive c:\Program Files (x86)\Atmel\Studio\7.0\tools\JTAGICE3\jtagice3_fw.zip
17:04:46: [archive] Temporary firmware directory: C:\Users\grgsa\AppData\Local\Temp\4c9f-860b-23de-9e5e
17:04:46: [archive] Parsing firmware manifest
17:04:46: [cli] Finished reading firmware from archive
17:04:46: [cli] Upgrading jtagice3:J30200026855
17:04:46: [cli] Connect; Application
17:04:46: [cli] Connect; Switch to upgrade mode
17:04:46: [cli] Connect; Upgrade Mode
17:04:47: [cli] GenericError thrown during firmware upgrade
17:04:47: [cli] USB driver initialization failed: No valid license (0x20000009).
17:04:47: [archive] Deleting directory: C:\Users\grgsa\AppData\Local\Temp\4c9f-860b-23de-9e5e
17:04:46: [cli] :
Same error, see my response above
:: Morten
yes I know ...so is the only solution to reset Windows ??
Or, in the other thread, try to replace the Jungo driver with a libusb one. There are some caveats with this that I have listed there.
:: Morten
No luck! I tried all usb-drivers.
jtagice3 goes to Download-mode - LED flashes and bldr driver loaded (also replaced this using zadig)
still "license error)
17:11:24: [cli] Start reading firmware from archive C:\Program Files (x86)\Atmel\Studio\7.0\tools\JTAGICE3\jtagice3_fw.zip
17:11:24: [archive] Temporary firmware directory: d:\temp\e196-a95f-e3b8-936e
17:11:24: [archive] Parsing firmware manifest
17:11:24: [cli] Finished reading firmware from archive
17:11:24: [cli] Connect; Application
17:11:24: [cli] Connect; Switch to upgrade mode
17:11:24: [cli] Connect; Upgrade Mode
17:11:24: [cli] GenericError thrown during firmware upgrade
17:11:24: [cli] USB driver initialization failed: No valid license (0x20000009).
17:11:24: [archive] Deleting directory: d:\temp\e196-a95f-e3b8-936e
edit ... hours later...
I made it work with a "from scratch installation" with my notebook. After fw-upgrade I compared the drivers: They are all the same!
Threre is the "atmel signed" winusb Data-Gateway driver used after powerup to connect the interface.
After change to bootloader-Mode the jungo-driver (windrvr6.sys) is used. This is also the same version on both devices.
I have no idea why upgrade fails on my desktop system.
