Studio 7 & WIN 10 Buils fail on make error 127
7 posts / 0 new
Do you the issue of this error?
"C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.1061\avr8-gnu-toolchain\bin\avr-gcc.exe" -x c -funsigned-char -funsigned-bitfields -DDEBUG -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -g2 -Wall -mmcu=atmega128 -c -std=gnu99 -MD -MP -MF "Battery.d" -MT"Battery.d" -MT"Battery.o" -o "Battery.o" ".././Battery.c"
/usr/bin/sh: C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.1061\avr8-gnu-toolchain\bin\avr-gcc.exe: command not found
make: *** [Battery.o] Error 127
Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "DomoHouseV6.cproj" -- FAILED.
Done building project "DomoHouseV6.cproj" -- FAILED.
Somehow it looks like you have sh running the command...
/usr/bin/sh
Also, an old avr8 toolchain? The toolchain invoked there does not seem to be the one from studio 7. Is this a custom makefile?
:: Morten
After the first upgrade to studio 7 and WIN 10 all the build issues is ok with all my projects (OK also with studio 6.2) This bug happen this week .
"Is this a custom makefile?" not It is not a custom makefile
I have not run the sh command
I have dawnload the last STUDIO 7 upgrade but i have the same issue.
in the tool option page : C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin
The last line of the  makefile after ​the files list is:
OUTPUT_FILE_PATH +=DomoHouseSolution_V6.elf
OUTPUT_FILE_PATH_AS_ARGS +=DomoHouseSolution_V6.elf
ADDITIONAL_DEPENDENCIES:=
OUTPUT_FILE_DEP:= ./makedep.mk
LIB_DEP+=
LINKER_SCRIPT_DEP+=
# AVR32/GNU C Compiler
The build of an legacy project with studio 6.2 is ok.
If I create a new project with the same files (A copy of the file of this legacy project in a new directory) he buildis not ok (Error 127). The new project creation provide this  general wraning : could not read project specific software Framework configuration setting  from 'essaiV-6' System.runtime.InteropServices.COMExeption: ,MethodName : get_ActiveConfiguration #AVR32 GNU C COMPILER
Now I remember : This week to make a new version of an legacy project I have made a copy of the *.C file , *.h file and the Old "Solution file" (Studio 6.1..) in a new folder (the solution file have the same icon that the *.c file since studio 7) a new build of this legacy project, before upgrade) with the legagy solution file in the "solution project" provide an error, then i have delated the "solution file" fron this new project. May be this mistake had provide this bug!
Hmh, could you post the full build log...
:: Morten
Yes, the build of the new project with the make error 127 provide only two file in the debug folder see MakeFileFromEssai.zip
MakefileFromEssai.zip and legacyprojectWithouterror.zip was two build with the same files ..
..without error an legacy project from 6.2 with any upgrade build with studio 6.2
...fromEssai the same lecagy project copy in a new folder to make a new project check (provide the error127) build with studio 6.2 (Idem with studio 7)
Thanks for your help
I think of having found the solution, it is a corruption of the window register. After a cleaning with Registry Reveiver ( who find more than 2000 Errors) the compilation of a new project is possible with studio 6.2, but not yet studio 7, I am going to have to reinstall studi07.
After a lot of work (and days) to clean the WINDOW registers bank , the remove of Studio (6.x and 7), all the "ATMEL " directories and all the "ATMEL" utilities. Studio 7 run and build without fix
For example after a Window Register clean up,  an new installation / remove of studio 6.2 leaves approximately 50 errors in window register.
