Twi Problem on xmega128a1
3 posts / 0 new
I have an issue using TWI on Xmega128a1
i would like to integrate HMC5883L magneto
according to the datasheet :
hmc5883l example
0x3C is the adress to write and 0x3D is to read from the device
my question is, in the loop mode, it's written send 0x3D 0x06
so should it should be like
twiname->MASTER.ADDR = 0x3C; // adress to write
twiname->MASTER.DATA = 0x06;
and than
twiname->MASTER.ADDR = 0x3D;
for (....)
    data[i]= twiname->MASTER.DATA
or should i write 0x06 to the adress to read like
twiname->MASTER.Data=0x06
for (...)
    data[i]=twiname->MASTER.DATA;
i tried with this code but when i debug the prog , it's  blocked  in twi_read() function ( it's shown in the code on comment) here :
while(!(twiname->MASTER.STATUS&TWI_MASTER_WIF_bm))
so why it's not blocked there in the main in write twi_write before entering in while (1) even i used
also is imortant to notice that this code works some times and the most of the time it's blocked
Need some help..
here is the code :
#include <asf.h>
#define CPU_SPEED 32000000
#define BAUDRATE    400000
#define TWI_BAUD(F_SYS, F_TWI) ((F_SYS / (2 * F_TWI)) - 5)
#define TWI_BAUDSETTING TWI_BAUD(CPU_SPEED, BAUDRATE)
#define HMC_SLAVE_ADDRESS 0x3C; // already shifted !!!!
TWI_t * hmc = &TWIC;
uint8_t twitest[6]={0x00, 0x70, 0x01, 0xA0, 0x02, 0x00}; // bytes to send like shown on the screen shot below
uint8_t bytetoreceive[6];
int16_t raw_x=0;
int16_t raw_y=0;
int16_t raw_z=0;
void twi_init(TWI_t * twiname){
	twiname->MASTER.CTRLB = TWI_MASTER_SMEN_bm;
	twiname->MASTER.BAUD = TWI_BAUDSETTING;
	twiname->MASTER.CTRLA = TWI_MASTER_ENABLE_bm;
	twiname->MASTER.STATUS = TWI_MASTER_BUSSTATE_IDLE_gc;
	return;
void twi_write(TWI_t *twiname, uint8_t *writeData){
	uint8_t i;
	twiname->MASTER.ADDR = HMC_SLAVE_ADDRESS;  // write to hmc
	while(!(twiname->MASTER.STATUS&TWI_MASTER_WIF_bm));
	for(i=0;i<6;i++){
		twiname->MASTER.DATA =writeData[i];
	return;
void twi_read(TWI_t *twiname, uint8_t *readData){
	// read from RTC
	uint8_t i;
	while(!(twiname->MASTER.STATUS&TWI_MASTER_WIF_bm));// ***************** THE PROG IS BLOCKET HERE ********************
	while(!(twiname->MASTER.STATUS&TWI_MASTER_WIF_bm)); // ******* or here ************
	for(i=0;i<6;i++){                  // read date and time
		while(!(twiname->MASTER.STATUS&TWI_MASTER_RIF_bm));
		readData[i] = twiname->MASTER.DATA;
	return;
void pointer_fix (TWI_t *twiname )
	twiname->MASTER.ADDR = HMC_SLAVE_ADDRESS;  // write to RTC
	twiname->MASTER.DATA =0x03;
		delay_ms(67);
int main(void){
	twi_init(hmc);
	twi_write(hmc, twitest);
	delay_ms(6);
	while(1){
		twi_read(hmc,bytetoreceive);
		raw_x = ((uint8_t)bytetoreceive[0])<<8;
		raw_x |= bytetoreceive[1];
		raw_z = ((uint8_t)bytetoreceive[2])<<8;
		raw_z |= bytetoreceive[3];
		raw_y = ((uint8_t)bytetoreceive[4])<<8;
		raw_y |= bytetoreceive[5];
		pointer_fix(hmc);
Thank you
Hi, the part where the datasheet says you should send 0x3d and then 0x06 makes no sense (it is a read request, the master is not supposed to send anything after initiating a read request). What they intend to say is send 0x3d and then read 6 bytes. It is actually stated above the section you quoted:
To clock out the new data, send: 0x3D, and clock out DXRA, DXRB, DZRA, DZRB, DYRA, and DYRB located in registers 3 through 8.
/Lars
