ATTiny-based stepper motor controller
13 posts / 0 new
I'm not sure if this is the correct category but since the Projects-section of this forum is not allowed to be used for such posts, I try it here:
At http://sourceforge.net/projects/tardyondrive-avr/ there is a complete implementation and documentation of an ATTiny-based stepper motor controller available. This includes hardware design (schematics), firmware that runs on the AVR, host-side client library that communicates with the controller and provides programming interface and a few example applications.
This controller can be used to move a stepper motor, it emits a direction signal and step-pulses for movement. It of course needs a power driver for the motor itself but full logic of controller (including acceleration/deceleration, referencing, external triggering of movements) is done on the ATTiny.
All sources and hardware layout are available for free. Comments, ideas and suggestions are welcome - but it would be best they arrive as patches to the sources provided at http://sourceforge.net/p/tardyondrive-avr/code/ci/master/tree/ ;-)
Kind regards
Oxy
*Moved by moderator*
Firstly welcome to AVRFreaks.
I don't know where you obtained the idea that a completed project like yours could not be submitted in the PROJECTS forum... but you are wrong. It is most welcome.
So please submit it.
Ross
Moderator
I got it from this posting saying that this sub-forum is for the project-area only - elsewhere it will be deleted. And since my project is not hosted in AVRFreak's project-area, it would have been subject to deletion...
Oxy
OK Oxy, I see what has happened. The forum in which you read that post was meant for discussion about projects posted in the https://www.avrfreaks.net/projects forum. The projects themselves were not allowed to be posted in the discussion area. A slight distinction that has obviously misled you.
But I now see that you have submitted your project in the projects forum itself.
I am personally interested in your project. Do you have a video of its usage at all?
Cheers,
Ross
EDIT for clarity.
Sorry, there is no video available.
We tested the controller and software together with a Powerlolu driver and a plain stepper motor. But since the power levels of AVRs outputs are high enough, it should work with every other (e.g. Pololu-based) stepper driver too.
With kind regards
Michael
Thanks Michael.
I notice that you mention USB 2.0, but isn't the code using the V-USB package that is rated USB 1.1 compliant... and not USB 2.0?
I should now move this thread over to the project discussion forum.
Cheers,
Ross
You are of course right - thanks!
Michael,
In your documentation, you show a schematic based upon the ATTiny85 with three signals labelled STEP, DIR and REF. Am I correct in "interpreting" REF as being the "ENABLE" line on the Powerlolu board?
Cheers,
Ross
... and I forgot... more questions.
Is the windows executable available for those who do not want to rebuild your source code?
And the .hex file for the Tiny85?
Ross
REF is an input which has to be connected with a reference switch that can be used for homing.
Binaries will be added to repository including both, the Windows DLLs and the AVR .hex file...should be available latest on Monday :-)
Oxy
Thanks Michael.
I look forward to giving your contribution a trial "run".
Enjoy the weekend.
Ross
I'm a beginner in these jobs and I want to make a system that just walks forward when I try to shut it down. My question is whether I should buy a car kit with encoders or without. In what cases are encoders justified?
So exactly how many threads do you think you can get away with posting that same message on before your account is deleted?
Don't cross post again.
Moderator
Topic locked
