Converting string to usnigned long for USART speed
19 posts / 0 new
Hi guys
I've been trying to implement a method for the user of my bus monitor project to be able to change the speed of the USART.
atoi() works fine, but not above a certain value (38400 +) as such values need to be stored in a long or unsigned long and itoa() falls over at that point.
Googling around, I've found that people are recommending strtol(). However, no matter what, I get nothing but 0 as a result.
Can anyone see where I'm going wrong?
int paramsCount = 0;
unsigned char params[10][32] = {{0}};
uint8_t COM_stop_bits = 1;
uint8_t COM_data_bits = 8;
unsigned long COM_baud = 19200;
COM_baud = strtol(*params[1],NULL,10);
COM_data_bits = atoi(params[2]);
COM_stop_bits = atoi(params[3]);
[edit] corrected itoa() to atoi()
You have an ltoa function in that bagotricks?
I tried "COM_baud = atol(params[1]);", but I get 0 out of that as well.
This is the entire function (mostly set up for testing while I iron out the bugs etc):
void cmd_COM(void)
	if (paramsCount!=4)
		displaytext(SerialStrPtrTable[6]);
		return;
char s[30], *cc;
	/*	always 1 start bit (always 1)
		5,6,7,8 or 9 data bits (default 8)
		no, even or odd parity (always no)
		1 or 2 stop bits (default 1) */
	//COM_baud = strtol(*params[1],NULL,10);
	unsigned long ul = 0;
	int i=0;
	sprintf(s,"[COM_baud=%u]",COM_baud);
	displaytext(s);
	do
		ul = SerialSpeedsPtrTable[i];
		//sprintf(s,"[%i]",ul);
		//displaytext(s);
		if ((COM_baud==ul) && (ul!=0)) break;
		i++;
	} while (ul!=0);
	if (ul==0)
		displaytext("Non-valid baud value\n\r");
		return;
	sprintf(s, "Read: %u, %u, %u\n\r", COM_baud, COM_data_bits, COM_stop_bits);
	displaytext(s);
Given the code
nowhere are you placing any valuer in params1.
Also, since params[1] is an array, you should pass it to strtol like this:
COM_baud = strtol(params[1],NULL,10);
Using a name of an array is equal to a pointer to the array (to be precise, to the first element of the array). Your extra * dereferences the pointer twice.
Here's a minimal demo using strtol
    unsigned char params[10][32] = {"whatever", "456"};
    unsigned long COM_baud = strtol((const char *)params[1],NULL,10);
@Bob: OP wants to convert a string to a long (not a long to a string). How would ltoa() help him with that?
sprintf %lu
Sorry. I just saw itoa and thought that ltoa would eat bigger numbers.
I just saw itoa
I was about to say you need new glasses, Bob. But then I saw that in the test of the OP "itoa" actually is used - while the code has the atoi().
So, it's me who need new glasses. (I already knew that..)
Apologies for causing confusion with the itoa() when I meant atoi().
params is used to hold the elements of a command string received from the user, with the space character used as a separator
So, if the user enters: COM 9600 8 1
Then:
params[0] = "COM"
params[1] = "9600"
params[2] = "8"
params[3] = "1"
I've tried using COM_baud = strtol((const char *)params[1],NULL,10); and also COM_baud = strtol(params[1],NULL,10);, but I still get back 0.
"still get back 0" - how do you know that? sprintf? You should use "%lu" for longs, not "%u".
What I find odd is that :
COM_baud = atoi(params[1]);
works fine and gives 9600 when params[1]="9600" (although bauds above 19200 break this)
However,
gives 0.
I've tried defining COM_baud as a long and unsigned long. Makes no difference.
I've tried your suggestion and get 0, but before that I was doing a simple if statement to check if the value was 0 or not.
Something you are not telling us. You need to show the whole program again. Or do something like:
char b[30];
char* s1 = "123456";
unsigned long l = atol(s1);
sprintf(b, "l1=%lu\n", l);
displaytest(b);
sprintf(b, "p1='%s'\n", params[1]);
displaytest(b);
l = atol(params[1]);
sprintf(b, "l2=%lu\n", l);
displaytest(b);
I've inserted your  code at the top of the routine and blocked o0ff any other code with a return statement (so only your code runs).
The result:
One thing to note is that the params array is not defined as a pointer (with a *):
Where-as yours is defined with a * :
This does not make any sense. The only explanation that I can think of is that it the compiler thinks that atol returns an int. Do you include ? (You have to!) Do you get any compilation warnings when you build your program?
Show us a small test program that demonstrates this. Also you never answered:
While this is on a PC not an AVR the fact is that this shows strtoul() working...
$ cat test4.c
#include <stdio.h>
char  params[4][10] = {
	"COM",
	"57600",
	"8",
	"1"
int main(void) {
	int baud;
	baud = strtoul(params[1], NULL, 10);
	printf("baud = %u\n", baud);
	return 0;
$ gcc test4.c -o test4
$ ./test4
baud = 57600
So how does your circumstance differ?
It has been a while since I tried compiling anything without -Wall. I see that by default gcc does not even complain about implicit declarations. Well, then it really must be a missing "#include <stdlib.h>". The implicit return types default to int. Since int and long are the same on the PC, everything is still good. But not good on AVR.
Oh well spotted - that'll teach me to use simple compiler invocations - I didn't even use a -O option either (not that it probably matters given the speed PCs run at!).
Brilliant! That sorted it out. As atoi() worked out of the box I didn't even think of the library being the issue.
Thanks again and to all who responded :)
